Old 08-24-2004, 12:10 AM   #1 (permalink)
Date registered: Jul 2004
HPS Supercharger for E430
Has anybody had their E430 or E55 outfitted with the HPS Supercharger? If so, I'd like to hear their experiences, good and bad. See it at MYHPS.COM[?]
bjue is offline   Reply With Quote
Old 08-24-2004, 05:13 AM   #2 (permalink)
solicit's Avatar
Date registered: Feb 2004
Vehicle: '81 280SE
RE: HPS Supercharger for E430
I haven't but there has been a few threads in the 210 E55 section about it. Type supercharger in the search option. Heres something to start with;
http://www.benzworld.org/forums/forums/thread-view.asp?tid=1176607&start=1&fid=6
Good luck
solicit is offline   Reply With Quote
Old 08-24-2004, 08:05 AM   #3 (permalink)
Fast430's Avatar
Vehicle: '02 E55
Works good. They need a software update on the ECM to firm shifts. I have had my car overrev. and hit the limiter before shifting to 2nd. a couple of times. Supposedly in the works. Also have a loud fuel pump, and haven't had them replace it yet. My 430 dyno'd at 385 hp at the crank before it had a lot of "learn in" time and with the stock exhaust. I'm guessing 395 HP with good gas and the AMG exhaust. The new system should make more power when it's available.
Fast430 is offline   Reply With Quote
Old 08-24-2004, 02:53 PM   #4 (permalink)
Date registered: Nov 2002
Vehicle: 560 SEC Supercharged(sold), E55 AMG, Renntech CL600 Bi-turbo, Porsche 928
You took it to an engine dyno or that's what you are calculating from a DynoJet chassis dyno?
Supercharged SEC is offline   Reply With Quote
Old 08-24-2004, 08:40 PM   #5 (permalink)
Fast430's Avatar
Vehicle: '02 E55
With cheesy gas and immediately after the install, 315.58 HP at the tires using a DynoJet 248C dyno. Standard 1.22 correction = 385.007 HP at the crank tested to SAE J1349. I don't think the exhaust helped as much as the break in period. It felt little stronger after about 10 days, but I can't say I felt much difference from the exhaust.
Old 08-24-2004, 10:25 PM   #6 (permalink)
18% loss is reasonable for the 210's tranny. My 560 SEC had 346 rwhp at 7 psi and no intercooler. I'm going to run her around 15 psi with an intercooler and see what she'll do.
Old 08-24-2004, 10:52 PM   #7 (permalink)
Date registered: Apr 2003
Vehicle: 2001 Brabus B10 E430
Fast430 - 8/24/2004 7:40 PM
Fast430,
Did you do a baseline run on the dynojet prior to the HPS s/c install? Any ideas what your rwhp & rwtq gains were? I noticed your in Ventura and being that I'm in the SFV area, just wondering who did the HPS install?
Thnx
Richard
2001 Brabus/HPS E430 Kompressor
2001 Lorinser ML430
2002 S500 Spt
2003 Town & Country Limited
2005 C6 Z51 Lingenfelter/Procharger
2006 Brabus ML500
rgaling is offline   Reply With Quote
Old 08-25-2004, 08:36 AM   #8 (permalink)
Fast430's Avatar
Vehicle: '02 E55
SEC, are these motors safe to 15 PSI? Do you know what the differences are on 55 VS 430 trannys? Can anything be done to improve the 430 trans?
HPS picked up my car and took it to Mech Tech motor sports and returned it after the install and dyno runs. Typically they give you the before and after dyno runs. I have them at home but I don't have the stock numbers with me (at work now). I believe with the 1.22 factor it was 272 HP stock, which is believable.
A 1.18 factor would be 372 HP after the SC, so over 100 HP gain. The negatives are the need for an ECM upgrade that is also supposed to be in the works and Adam has promised free of charge. It's nothing major, but the car has hit the rev limiter a few times on the 1-2 shift. My fuel pump has gotten loud, and the hotter it is, the worse it sounds (Adam says they will replace it). They use a Powerdyne FMU that actually incorporates a Porsche fuel pump (go figure), but it works fine. It may be the source of a stumble that I get, especially at high altitudes and temps. Usually runs just fine, just had a slight stumble when accelerating from a 60 -70 mph cruise coming and going to Vegas, and once over the grapvine. Nothing drastic, but I had a code in the ECM (can't remember the number) for left or right bank too rich? Never had a MIL, never had any discernable detonation at any temp, just grins for days.
Old 08-25-2004, 08:35 PM   #9 (permalink)
"SEC, are these motors safe to 15 PSI?"
I'll soon find out! That is, on my 560 SEC.
"Do you know what the differences are on 55 VS 430 trannys? Can anything be done to improve the 430 trans?"
I believe the E55's are programmed for faster shifts, are beefed-up to handle more power, and have positive locking torque converters. I think the dealership can reprogram the tranny for faster shifts. There is a huge difference in feel between the two trannys. It's like night and day.
Old 08-25-2004, 10:17 PM   #10 (permalink)
Fast430 - 8/25/2004 7:36 AM
Fast430...thnx for the writeup
Hope the ECM upgrade gets resolve by HPS! Knowing Adam he's very adamant in keeping his customers happy [:D]
