Old 08-22-2004, 05:43 PM   #1 (permalink)
HERNANZA's Avatar
Date registered: Aug 2003
Vehicle: E 320
CODE 1420 PLEASE HELP...
Have a 97 E320. Have a PO1420 code causing my check engine light to illuminate. The code is Catalyst Temperature Sensor Failure
My question is where is this sensor located?? Is it where I can get to it and change it out, or get a dealer screwing and have it done there.
Thanks
HERNANZA is offline   Reply With Quote
Old 08-23-2004, 04:23 AM   #2 (permalink)
teky's Avatar
Date registered: Jun 2004
Vehicle: chris
RE: CODE 1420 PLEASE HELP...
P1420 is secondary air injection (air) valve solenoid-defective, fix is faulty wiring-fuse-air valve/solenoid-ECM
check the fuses first
teky is offline   Reply With Quote
