Old 08-21-2004, 08:24 PM   #1 (permalink)
Date registered: May 2004
Send a message via AIM to philly
Climate control HELP
Please HELP!
My climate control always give cold air (which is good for summer); but when I am trying to increase the temperature air doesn't doesn't warm up. What might be wrong???
Do I have to contact the dealership or it's easy to fix myself???
Thank you!
philly is offline   Reply With Quote
Old 08-22-2004, 03:48 AM   #2 (permalink)
Date registered: Jul 2004
RE: Climate control HELP
it can be either of two things.. could be the AAC control unit.. or your blend air flaps are stuck.. meaning that there is a vacuum leak.. since the actuators are vacuum controlled..
one question though.. do you hear the flaps moving when changing temps or anything??
BenzTech is offline   Reply With Quote
Old 08-22-2004, 07:19 AM   #3 (permalink)
No, I don't hear anything while changing the temperature. But vaccum I believe is OK, cause doors are working properly.
Might be something else?
