Old 08-17-2004, 11:41 PM   #1 (permalink)
Date registered: May 2004
Vehicle: 1998 E320 sedan
antenna adapter
I am installing an FM modulator to use with my XM radio. My car is a 98 E320. The antenna connector for the stock radio is a different type than the American style antenna connection on the fm modulator. Is there an adapter that I can buy to complete the installation? Where can I buy it at? Thanks
wsimpson110 is offline   Reply With Quote
Old 08-18-2004, 11:11 AM   #2 (permalink)
E-Klasse's Avatar
Vehicle: E320, SLK320, MKV Jetta TDI, Mini Cooper S
RE: antenna adapter
You may have to cut and splice in the adaptor. I have seen FM modulators for CD stackers done this way at the back of the radio becuase the connections are not like the US type.
I assume no liability for any incidental, consequential or other liability from the use of this information. All risks and damages, incidental or otherwise, arising from the use or misuse of the information contained herein are entirely the responsibility of the user. Although careful precaution has been taken in the preparation of this information, I assume no responsibility for omissions or errors.
E-Klasse is offline   Reply With Quote
Old 08-19-2004, 10:27 AM   #3 (permalink)
Date registered: Oct 2002
Vehicle: E320
RE: antenna adapter
I use a FM modulator with the stock radio. You really need two adapters. One to adapt the input of the modulator into the radio, then the second to adapt the antenna plug into the modulator. I found a kit at WalMart that had both adapters in the same kit. It was Metro XM radio adapter kit. There are many extra plugs and sockets arrange in a hub connector. Once I determined which ones I wanted, I cut the rest off.
rob_fed is offline   Reply With Quote
