98 E320 auto tranny not shifting - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 08-09-2004, 04:55 PM Thread Starter
Date registered: Aug 2004
My mom has a 98 E320 with about 60k miles on it, every now and then the tranny will start acting up and not shift gears, then all of a sudden it will start working again (right now it's not), does anyone know what this could be?
H22CL is offline
post #2 of 10 (permalink) Old 08-09-2004, 07:14 PM
Shermio's Avatar
Date registered: Jul 2004
Send a message via MSN to Shermio
RE: 98 E320 auto tranny not shifting
Lol Transmission Failure???
It's A Bit Hard To Tell Without Specific Details... Like What Happens Leading Up To It Not Shifting... Any Noise... Etc Etc....
d(O_o)b
Shermio
http://perpetualdreamer.deviantart.com
1999 Mercedes A160 Avantgarde RS (SOLD)
1996 Mercedes E230 (First W210 E-Class In New Zealand)
2002 Mazda MX-5 SE (1 Of Only 15 In New Zealand)
Shermio is offline
post #3 of 10 (permalink) Old 08-09-2004, 09:12 PM Thread Starter
no noise, will just like stay in first gear without changing into the other gears. still has reverse by the way!
H22CL is offline
post #4 of 10 (permalink) Old 08-10-2004, 09:58 AM
Vehicle: 2000 ML430
That sounds a lot like "Limp Home Mode"... look in your manual for that... I don't know how to get it out of that mode though :)
unferth is offline
post #5 of 10 (permalink) Old 08-10-2004, 10:34 AM
Vehicle: 1997 E420
Have your mechanic check the TCU, or ETC, which is the transmission control unit. It is a plastic frame which has electronics, some solenoids, and wiring harness on it mounted to the transmission. Sometimes fluid will leak on to this unit which will cause the transmission to shift erratically, often times when you shut the car off and turn it back on the shifting is corrected.
This does eventually get worse, and you will notice hard shifting from park to first, and then egine codes (like transmission sensor errors) which will give you "Check Engine Electronics" and then often times limp mode which is what your getting now.
But have them check that first, before they try and get you for a 6800.00 new transmission. This happened to me at 67K
Good Luck
osiris667 is offline
post #6 of 10 (permalink) Old 08-10-2004, 06:28 PM Thread Starter
Thanks, I will look into that some time later in the week. and yes, check engine electronics is on.
H22CL is offline
post #7 of 10 (permalink) Old 09-11-2005, 09:01 PM
Date registered: Aug 2005
Vehicle: 1999 E320, 2001 E320
Quoted: 13 Post(s)
Osiris667,
You said "TCU is mounted to the transmission.", is the TCU indide the transmission? Do we need to take the AT pan off to access it?
cerritos is offline
post #8 of 10 (permalink) Old 09-11-2005, 11:47 PM
zam2000's Avatar
Date registered: Jan 2004
Vehicle: S, GL, Escalade ESV, my shoes
Happened to my 98W210 too: sometime the car would not shift out of first gear. I have to put it back to "Park", then "D" again, then it's back to normal.
Took the car to the shop, they found that oil leak into the TCU, and cause the electronic part to go wahooo once a while. After they cleaned it up & reseal the TCU ($140 total), don't have problem anymore.
H22CL - 8/9/2004 7:55 PM
zam2000 is offline
post #9 of 10 (permalink) Old 09-12-2005, 08:34 AM
Vehicle: 2008 BMW 528i,1999 Lexus 400LS, 2014 e250 BlueTec
Quoted: 5 Post(s)
Send a message via MSN to Raylee177 Send a message via Yahoo to Raylee177
One of common problems on W210 is TCU leak. My car is 2001 E320 and I had leak that needed TCU replaced.
Raylee177 is offline
post #10 of 10 (permalink) Old 09-12-2005, 04:28 PM
mercfansydney's Avatar
Date registered: Sep 2005
Vehicle: E240 1999
Happened to me too. I discovered the engine had very little oil. I filled it and it was fine.
mercfansydney is offline
