| RE: removing rear view mirror The mirror is held on by spring tension and is designed to break away in an accident so it can be removed by pushing it forward and down. If you push up on the headliner, you can see the spring in a horizontal position above the mirror. There is a power connector or plug up there as well so disconnect that before you take it off in case you yank on it too hard when removing it. You can get a flat screw driver above it as well and push the spring to the side and then pull the mirror down.
I assume no liability for any incidental, consequential or other liability from the use of this information. All risks and damages, incidental or otherwise, arising from the use or misuse of the information contained herein are entirely the responsibility of the user. Although careful precaution has been taken in the preparation of this information, I assume no responsibility for omissions or errors. |
