Old 06-06-2004, 08:59 PM   #1 (permalink)
Date registered: Aug 2003
Vehicle: MBNZ E 320
97 E-320 Rear window fall ....
As we all know this is a factory problem... it hit me too lol....i toke off the door panel and soo the mass...Any ideas how much it will cost me? I think the whole mechanizm has to be replaced ..
Thanks
alfa01 is offline   Reply With Quote
Old 07-01-2004, 12:11 AM   #2 (permalink)
SilverBenz's Avatar
Date registered: Jan 2004
Vehicle: '97 E320
RE: 97 E-320 Rear window fall ....
I've had this problem with both my '97 E320 and my '92 190E. After taking it to the Mercedes dealer, I spent about $350 for the window. They had to replace the gears for the window also, so I'm sure they'll have to do the same for yours. Hope this helps.
SilverBenz is offline   Reply With Quote
Old 07-13-2004, 06:05 PM   #3 (permalink)
Date registered: Jul 2004
my 2000 e320 wagon right rear power window failed without warning this week (50K miles).
Makes crunching sounds going down, and won't go back up w/o manual assistance (won't stay up either).
Is this a factory issue?
macjack is offline   Reply With Quote
Old 07-14-2004, 07:48 AM   #4 (permalink)
E-Klasse's Avatar
Vehicle: E320, SLK320, MKV Jetta TDI, Mini Cooper S
I replaced both of mine. Here is the assembly that needs to replaced. The originals are rivited on so you just have to drill them out. The picture is without the motor that mounts in the center.
I assume no liability for any incidental, consequential or other liability from the use of this information. All risks and damages, incidental or otherwise, arising from the use or misuse of the information contained herein are entirely the responsibility of the user. Although careful precaution has been taken in the preparation of this information, I assume no responsibility for omissions or errors.
E-Klasse is offline   Reply With Quote
Old 07-14-2004, 11:34 AM   #5 (permalink)
Date registered: Oct 2002
Vehicle: E320
I did the left rear door at the end of last year. The window regulator part was about $80 with shipping included. You probably will not need the replacement motor, as the old one can be reused.
Search this forum, someone has documented the process with pictures. Or it maybe on the other "mb*****.org" forum.
rob_fed is offline   Reply With Quote
Old 07-14-2004, 05:55 PM   #6 (permalink)
Vehicle: 1998 E240 Elegance
Send a message via MSN to exekut0r
My rear window failed about 2 months ago.. It was stuck and couldn't go back up. Had to call Merc roadside assistance and they cut the regulator because it was all tangled up.
I called up all the Mercedes Benz Workshops and each were asking $450-$550AUD!!! (thats around $470US for all you Americans!) This is a window regulator!
Anyway I did alot of research and managed to get original mercedes part installed for $300AUD($270US)yesterday [:)]
exekut0r is offline   Reply With Quote
Old 07-15-2004, 01:02 AM   #7 (permalink)
sorry last price was $230US, not $270
Old 07-15-2004, 04:04 PM   #8 (permalink)
E-Klasse's Avatar
If you can buy it without the motor, you can save money. I reused the motors on both of mine.
Old 07-21-2004, 01:28 AM   #9 (permalink)
Vehicle: 1997 e420 black opal
You car buy the regulators and also the rivits that go with the assembly at fastlane over at mercedesshop.com I think I paid like $80 for mine. Its not to hard to figure out.
craiggotgame is offline   Reply With Quote
Old 07-27-2004, 01:02 PM   #10 (permalink)
Just happened on my 99 e320. Dealer replaced and used the existing motor. Approx. $300-$350 out the door. I asked him when the other side was going to go. He said anytime, so just don't use it. He was kidding.
train is offline   Reply With Quote
