Old 06-03-2004, 02:43 PM   #1 (permalink)
Serrano15757's Avatar
Date registered: Jun 2004
Garage Door Programing
How do I program the garage door to work on the rear view mirror buttons? I see three buttons under the mirror housing. I was told you can program these to operate different remotes. I that true? How do I program them
Thanks
Jose
Los Angeles
Serrano15757 is offline   Reply With Quote
Old 06-03-2004, 09:27 PM   #2 (permalink)
Date registered: Jan 2004
Vehicle: 1959 220S cabriolet, 1983 240D original owner, 1999 E300 turbo diesel, 1988 560SL
RE: Garage Door Programing
Clearly and thoroughly covered in the owner's manual.
Len
sokoloff is offline   Reply With Quote
Old 06-03-2004, 09:57 PM   #3 (permalink)
Gee thanks Len.
I bought the car used and it didn't come with an owners manual. If I had an owners manual, I wouldn't have asked on this message board. Some Help[:(!]
Old 06-04-2004, 06:14 AM   #4 (permalink)
You're going to need the owner's manual for a lot more than the garage door opener programming. You can get one at your local dealer or by calling 1-800-FORMERCEDES. Last I recall, they were about ten bucks or so.
There are some folks who have an owner's manual and are too damn lazy to read it. Why should I go out to my garage to get mine, look it up and type up directions that someone already has? Sorry, just venting, not at you Jose.
There are a couple of pages of directions for setting up the garage door opener. Need to first know whether you have a garage door with a rolling code feature or not. That's one page of directions. Let me know and I'll help you out.
Len
'99 E300TD 65,000 miles
Old 06-04-2004, 12:21 PM   #5 (permalink)
E-Klasse's Avatar
Vehicle: E320, SLK320, MKV Jetta TDI, Mini Cooper S
Serrano15757 - 6/3/2004 4:43 PM
Thanks
Jose
Los Angeles
Go to the Homelink webpage or do an internet search. Homelink is in many cars and is programmed the same way no matter what kind you have.
What year is your E-Class? If it is a 96 or 97, then it will not do rolling code garage doors like the new ones or Gennie are. 98 was the first year to be of much use as far as programming the garage door buttons.
If it has been programmed before, push and hold the 1st and 3rd buttons until the light starts flashing. This will erase anything that has been programmed in them before. You have to have the ignition key in position 1 for it to be powered up.
Hold your garage remote next to the 3 buttons and push it along with one of the buttons. It should flash when it has been programmed.
Check out the subject of Homelink for more details.
I assume no liability for any incidental, consequential or other liability from the use of this information. All risks and damages, incidental or otherwise, arising from the use or misuse of the information contained herein are entirely the responsibility of the user. Although careful precaution has been taken in the preparation of this information, I assume no responsibility for omissions or errors.
E-Klasse is offline   Reply With Quote
Old 06-06-2004, 07:35 PM   #6 (permalink)
E-Klasse's Avatar
Here is the Homelink manual to download...
http://www.homelink.com/program/hlmanual.pdf
Here is the website...
http://www.homelink.com/program/download.tml
Go to the programming Homelink for the first time section and let us know if this works out for you...
Old 06-07-2004, 10:26 AM   #7 (permalink)
Dude!
Thanks alot for your help. I downloaded the pdf and followed the instructions. I really appreciate your help.[:D] Now both my doors work. THANKS!!![:D][:D][:D]
Old 06-09-2004, 10:32 PM   #8 (permalink)
Ruffrob's Avatar
Vehicle: 2003 Obsidian Black E320
Send a message via AIM to Ruffrob Send a message via Yahoo to Ruffrob
E-Klasse,you're a life saver,i followed your instructions and.........BAM!!!!,no more fishing for the little square remote my cheap-ass building supplies to it's tenants. I can thankfully hand it back to them......thanks again!!!
1997 Black E320
1994 Black Acura Legend L (gone,but not forgotten)
Ruffrob is offline   Reply With Quote
Old 06-10-2004, 08:15 AM   #9 (permalink)
E-Klasse's Avatar
Glad to hear it. Not only are they more convenient but you never have to change batteries in the remote again.
Old 08-30-2004, 07:40 AM   #10 (permalink)
shiraz's Avatar
Date registered: Aug 2004
Vehicle: MB E430 Avantgarde
That feature was never available in South Africa. To add this, would I have to change my entire mirror? Or is it a separate unit that can be added to the mirror housing?
shiraz is offline   Reply With Quote
