Please help..need to replace left front fog light..don't see how to get at it..anyone changed theirs? Also, need to replace rear brake pads..which pads do I need, 1 retsaining pin or 2 retaining pin pads.
There is a peice of plastic under the front bumper (just under the foglight). You need to remove the clip and then just remove the plastic peice. You will have access to the bulb then.
Just be careful not to shake the foglight too much otherwise you will end up doing what i did and now my foglamp doesn't sit flush with the bumper.
This is better described in the owners manual, I think its in the "Exterior" book, under lighting.
