Old 05-27-2004, 10:16 PM   #1 (permalink)
mischief's Avatar
Xenon bulb
Does anyone know the bulb size for the Xenon light system for a 2000 E 430 4Matic? Also does anyone know how to replace the xenon bulbs? The owners manual tells you go to the stealership to get it worked on, but i really don't feel like getting raped by them for something I should be able to do myself.
1999 ML 320 - gone
2000 E 430 4Matic - sold
2001 SLK 320 - history
2004 C 32 AMG
2004 S 500 4Matic
2005 S 500 4Matic
2006 SLK 55 AMG
mischief is offline   Reply With Quote
Old 05-31-2004, 06:29 AM   #2 (permalink)
Storm's Avatar
Date registered: Jan 2004
RE: Xenon bulb
I may be wrong but I think it is H7.
Storm is offline   Reply With Quote
Old 05-31-2004, 02:21 PM   #3 (permalink)
Date registered: Nov 2002
Vehicle: 560 SEC Supercharged(sold), E55 AMG, Renntech CL600 Bi-turbo, Porsche 928
RE: Xenon bulb
A xenon bulb is a xenon bulb and not an H7. You can get your bulb from the stealership or from an online vendor. I get mine from these guys: 8007415252 Rusty's Parts. Give them a call and they can get the bulb you need at a better price than the stealership. You can change the bulb yourself.
The bulb usually does not go bad. The problem is usually the ignightor. Is it your passenger side xenon that is out? If so, these are known to go bad.
Supercharged SEC is offline   Reply With Quote
Old 06-06-2004, 10:46 AM   #4 (permalink)
Date registered: Jun 2004
Send a message via AIM to EShklovsky
RE: Xenon bulb
I am wondering what size they are to buy I wanna upgrade to 8000k you can blubs you can purchase them on ebay for under 100 dollars is it worth it, and what size of bulbs do I need?
EShklovsky is offline   Reply With Quote
Old 06-06-2004, 05:48 PM   #5 (permalink)
Date registered: Mar 2004
RE: Xenon bulb
The type of xenon bulb used is Type D2R. There are different Kelvin temperature colour of the bulb. You go to www.plasmagarage.com and it is rather informative on that web. Yes you can change the bulb yourself.It is so easy.Good luck.
SL83A is offline   Reply With Quote
Old 06-10-2004, 08:54 AM   #6 (permalink)
RE: Xenon bulb
I just installed xeon light system, from a diffrent E430 with xenons, everything worked fine for a bit, but I am noticing one of the lights getting a little yellow sometime, aslo the check your bulbs light came on, and all the blubs work fine , I am wodering if I change the bulb would this solve my problem, also is there a way to test if its the blub or something else?
Old 06-14-2004, 09:32 PM   #7 (permalink)
mischief's Avatar
RE: Xenon bulb
Yeah the passenger side bulb is not the same color as the driver side. The passenger side bulb turns pinkish after the light come up to temperature. I thought it was a system problem, but the dealer says its a blub problem.
