Old 05-26-2004, 12:55 PM   #1 (permalink)
Date registered: May 2004
EC on Climate control always on
The EC button on my 1997 e320 stays on constantly and never goes off. I know this prevents the compressor from engaging. I checked the freon level and it's normal. Somebody help me !
archie5275 is offline   Reply With Quote
Old 05-26-2004, 01:06 PM   #2 (permalink)
Vehicle: ML500, E320 4Matic
RE: EC on Climate control always on
There is obviously something wrong. You must pull any codes from the unit to detirmine whats bad.I Believe there is a way to do this from the unit yourself but you must have the info on what each code means. Perhaps you should take it to a dealer
sosh is offline   Reply With Quote
Old 05-27-2004, 03:22 AM   #3 (permalink)
Vehicle: E220T cdi
Hi!
I have the same problem or at least the same symtom.
You have to read out sensors and errorcodes from the climate control display and figure out if there is something that sticks out.
Follow this link below:
http://www.continentalimports.com/ser_ic40142.html
Morgan
mgyl is offline   Reply With Quote
