Old 05-08-2004, 11:45 AM   #1 (permalink)
dubE420's Avatar
Date registered: May 2004
Vehicle: 1997 Mercedes E420
Send a message via AIM to dubE420
head light lens oxidation
What is the best way to remove oxidation off of the head lights? Is there a cleaner made specifically for this?
dubE420 is offline   Reply With Quote
Old 05-08-2004, 04:44 PM   #2 (permalink)
Date registered: Oct 2002
Vehicle: E320
RE: head light lens oxidation
You can buy a special headlight polishing kit. It will contain a hard buffing wheel and some special compound. It will work, but the part that is oxidizing is the "hard" layer of the headlight. Once you remove the oxidation, the coating is gone too. Basically, it will continue to pit with road debris.
http://www.ipsglass.com/acrilic-polishing-kits.htm
I use Flitz brand metal polish. Metal polish? Flitz brand polish works on any non-porous surface. It has no abrasives and it works great on headlights.
http://www.flitz.com/
rob_fed is offline   Reply With Quote
Old 05-09-2004, 09:49 AM   #3 (permalink)
dubE420's Avatar
Thanks a million. I will definetely try these produsts. My lights are not that bad but I want to catch the problem before I have to purchase a new assembly to achieve the look that I want.
Old 05-10-2004, 04:52 PM   #4 (permalink)
Vehicle: E320
I should add, anything you use that takes off the oxidation is taking some part of the hard coating off. It is a catch22 situation. But, you use a Flitz type of product or even some Meguiar's plastic polish, you can keep the headlights from looking yellow.
I don't think the problem is that big a deal on MBZ cars. If you look in your local parking lot, look at mid-nineties and earlier Ford products, like the Thunderbird. There you will find lots of yellow lens. Garaged cars probably would far better too.
Note, I am not Ford bashing, plenty of other makes of the same era are doing the same thing, just using the T-bird as an example.
Old 05-16-2004, 09:42 PM   #5 (permalink)
merouby's Avatar
Date registered: Jan 2004
Vehicle: 84 300SD
Guys,
The European-spec headlights which look identically the same to the US-spec, are made of GLASS not the "US-spec-will-fog" plastic. So they always look new and fresh.
Try to buy these from ebay.de or off the internet.
Case in point:
http://cgi.ebay.de/ws/eBayISAPI.dll?ViewItem&category=44243&item=7902320 336&rd=1
http://cgi.ebay.de/ws/eBayISAPI.dll?ViewItem&category=44243&item=2477803 666&rd=1
Plus the above are facelifted to appear like the newer E class.
merouby is offline   Reply With Quote
Old 05-20-2004, 01:55 PM   #6 (permalink)
Date registered: Jan 2003
Vehicle: 84 300SD 98 E300D
I have had success polishing the headlight. For product used and before and after pics, see
Opague Headlights - Polished - ShopForum
richunters is offline   Reply With Quote
