Old 03-31-2004, 10:14 PM   #1 (permalink)
Date registered: Feb 2004
Vehicle: Mercedes E200 W210
Send a message via Yahoo to prasanna
Brake disk corrosion + sound when braking
Hi all,
I have noticed that the brake disks on our merc e200 are discoulored, and not shining bright as on other cars(mainly japanese cars) Is this normal for mercs, or is there something wrong? Also there is a squeking noise when braking, even after installing new brake disk and callipers.
Someone who knows please reply
prasanna is offline   Reply With Quote
Old 03-31-2004, 11:10 PM   #2 (permalink)
Storm's Avatar
Date registered: Jan 2004
RE: Brake disk corrosion + sound when braking
Sounds to me like your Brake discs are grooved. This tends to happen alot where I'm from due to improper compounds of pad being used. The easiest solution on my side of the world is to get your discs on a lathe and have a MM or so ground off to make their faces flat & Shiny again. However I would NOT recommend this for you since you have already changed your discs & Pads. Its possible the setup you have don't work well together, have you tried to change the pad to a different compound?
Till now only my CL has shiny discs, the rest are all a bit dull, i guess its a merc thing.
If you really want the shiny look for your discs then what I would suggest is to get new (Aftermarket - Ferodo Brembo A.P.Racing) discs and pads and bed them in properly and gently for the first few hundred kilometers. But if you do decide to do that, make sure to go for a tried and tested setup for the 210.
Hope this helps[:D]
Storm is offline   Reply With Quote
Old 04-01-2004, 12:54 AM   #3 (permalink)
ae86pwr's Avatar
Date registered: Nov 2003
Vehicle: 98 ML320 / 06 S2000
Send a message via AIM to ae86pwr Send a message via MSN to ae86pwr
prasanna - 4/1/2004 9:14 AM
did you apply the gooey anti-squeal brake paste from mercedes on the back of the brake pads??
ae86pwr is offline   Reply With Quote
