» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W210 E-Class
Old 03-15-2004, 09:11 AM   #1 (permalink)
Art
Vehicle: 1987 300E
Radio volume control
I have a 97 E320 with the factory radio. The volume control is very strange - sometimes turning clockwise just a small amount will cause the volume to go off completely and have to be reset to "normal" parameters using the procedure in the owners manual. Same for turning counter clockwise. Anyone else had this problem? Any suggestions?
Thanks.
Art is offline   Reply With Quote
Old 03-16-2004, 07:51 AM   #2 (permalink)
E-Klasse's Avatar
Vehicle: E320, SLK320, MKV Jetta TDI, Mini Cooper S
RE: Radio volume control
Is the car moving while you are adjusting the volume? The stereo also has an automatic volume adjustment that increases the volume as the speed of the car increases. You can disconnect this input on the back of the stereo.
I assume no liability for any incidental, consequential or other liability from the use of this information. All risks and damages, incidental or otherwise, arising from the use or misuse of the information contained herein are entirely the responsibility of the user. Although careful precaution has been taken in the preparation of this information, I assume no responsibility for omissions or errors.
E-Klasse is offline   Reply With Quote
Old 03-16-2004, 10:52 AM   #3 (permalink)
Art
Vehicle: 1987 300E
The car is moving. My guess is that the same problem exists when not moving - I'll check it out.
Thanks for the reply.
