Old 01-05-2004, 02:27 PM   #1 (permalink)
Date registered: Jan 2004
Looking for an E320 4matic Wagon. Advice?
Shopping for '00-'03 model
Low Miles
Any issues to look out for?
Is Starmark Worth it?
CookiePuss99 is offline   Reply With Quote
Old 01-07-2004, 11:38 PM   #2 (permalink)
Mark Cummins's Avatar
Vehicle: W211/W210wagon/W209
RE: Looking for an E320 4matic Wagon. Advice?
On The W210 98/02
Crank pullies fail
motor mounts fail
cat converters fail
dash boards crack
fuel senders work part time
front seat frames rock (LOOSE)
front lower control arms ..bushings fail
A/C evap temp sensors fail
mass air sensors fail
Dont get me wrong I Love my E class wagon!
I Had a ML what a POS!!!!!!!
Get a dealer to do a Pre purchase inspection..run a VMI for service history,,car fax wont hurt...
I was a MB tech...so all I saw were the bad ones all day ...
Mark Cummins is online now   Reply With Quote
Old 01-12-2004, 07:51 AM   #3 (permalink)
texnteg's Avatar
Date registered: Sep 2002
Vehicle: 2002 E320W4
Send a message via AIM to texnteg
the 4matic system is absolutely wonderful, much better than quattro could ever be. thus far, our 2002 E has not had any problems whatsoever. maybe luck, i don't know. i thought the cracked dash's were on the 96-98 w210's. the crank failing was fixed by 2001(early 2002 model year). cats can go out on any car, its the supplier, not mercedes. motor mounts can go out, but seems unlikely. hell, as long as everything is under warranty...it's taken care of.
we did get the extended warranty, mainly because we plan on keeping the E around for a long time. i would say Starmark is worth the extra bit of money. and even if you don't go that route, any mercedes you get will have records, of all maintenance and repairs done, accessible at the dealership.
"Steel Stallions: Rollin' Hard, Rollin' Fast, Rollin' By" Robert Earl Keen
1990 Honda Integra
1989 M-B 190DT EvoI<< sold
2002 M-B E320 4matic
searching for a 300E 4matic
texnteg is offline   Reply With Quote
