Old 12-18-2003, 10:37 AM   #1 (permalink)
E-Klasse's Avatar
Vehicle: E320, SLK320, MKV Jetta TDI, Mini Cooper S
Center brake light upgrade...
Before:
After:
I replaced the rear shelf in my 96 E-Class with one from a 2001 with the new center brake light. A month or so ago I instaled a 2002 E55 rear bumper and I had installed the 2002 rear tail lights a year ago. It all looks 2002 from the back.
It is kind of a tribute the the W210 E-Class from 96 to 2002. You see the front as a 96 then the back as a 2002. The year it came in and went out...
I assume no liability for any incidental, consequential or other liability from the use of this information. All risks and damages, incidental or otherwise, arising from the use or misuse of the information contained herein are entirely the responsibility of the user. Although careful precaution has been taken in the preparation of this information, I assume no responsibility for omissions or errors.
E-Klasse is offline   Reply With Quote
Old 12-19-2003, 03:47 PM   #2 (permalink)
Date registered: Feb 2003
Vehicle: w210
RE: Center brake light upgrade...
Very very nice E-Klass.[;)]
I would like to do this upgrade myself too. Just haven't got any luck finding the rear panel.
david_w210 is offline   Reply With Quote
Old 12-21-2003, 08:34 AM   #3 (permalink)
E-Klasse's Avatar
The person I got mine from upgradded to a rear shade in his 2001. The rear shade takes a 2 part rear shelf instead of the 1 part type.
Old 12-21-2003, 08:11 PM   #4 (permalink)
texnteg's Avatar
Date registered: Sep 2002
Vehicle: 2002 E320W4
Send a message via AIM to texnteg
looks great. got the best looking front and the best looking rear.
"Steel Stallions: Rollin' Hard, Rollin' Fast, Rollin' By" Robert Earl Keen
1990 Honda Integra
1989 M-B 190DT EvoI<< sold
2002 M-B E320 4matic
searching for a 300E 4matic
texnteg is offline   Reply With Quote
Old 12-24-2003, 02:23 PM   #5 (permalink)
E-Klasse's Avatar
Well, I do try to work out on a regular basis... Thanks
Old 12-24-2003, 06:53 PM   #6 (permalink)
texnteg's Avatar
hehehe....i know you know i meant the front of the car...right??
Old 12-27-2003, 04:47 PM   #7 (permalink)
Date registered: Nov 2003
Vehicle: E430 AMG
Hi E-Klasse,
any problems at all, I would like to do it to my 98 E430, chnage the rear light that is!
regards
mrfirepro is offline   Reply With Quote
Old 12-28-2003, 08:35 AM   #8 (permalink)
E-Klasse's Avatar
The only trick is getting the rear headrests off. Once they are out of the way, there are only 2 screws that hold the shelf in. The old brake light has a base that is snapped in to the metal under the shelf. The brake light connector is plugged in to that base. Pull the base out and put a new connector on the wires to connect to the new brake light. You can change the connector from inside the trunk because the wires can hang down in to the trunk.
Old 12-29-2003, 10:54 AM   #9 (permalink)
Vehicle: E430 AMG
RE: Center brake light upgrade...& IC Upgrade
Hi again E-Klasse,
can you email me at paul.darke@ntlworld.com.
I have all the instructions completed for the IC and steering wheel upgrade, unfortunatley the file is 68MB due to the photos. The instruction took longer to write than doing the work.
regards
Paul
PS thanks for the shelf tips, does the light come with the parcel shelf and do you have part numbers.
Old 12-30-2003, 04:47 AM   #10 (permalink)
Date registered: Dec 2003
Vehicle: 2001 W210
Hi E-Klasse,
Thank you for sharing your experience.
I have E-Class 2001, from time to time, I hear a noisy sound (zzzz, zzzzz) specially when driving on bad roads. I believe it is coming from the rear shelf or the rear headrests.
I would appreciate if tell me how can I get the rear shelf off. You said there are 2 screws that hold the shelf, where are they located?
Thank you in advance
Mike2001 is offline   Reply With Quote
