Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Coupe/Convertible Forums > W209 New CLK Class
Old 09-17-2008, 11:09 AM   #1 (permalink)
Date registered: Sep 2008
Standard Headlights to Xenon
Hi again all --
What exactly would be involved in replacing my stock headlights to use the Xenon bulbs? Is it just a matter of changing out the bulbs, or does it involve ballasts, wiring, etc?
It's for a 2005 CLK 320.
Thanks!
Heat
heatmizuh is offline   Reply With Quote
Old 09-17-2008, 11:29 AM   #2 (permalink)
Mark Cummins's Avatar
Vehicle: W211/W210wagon/W209
Its Best to change out the Complete Headlight assy to a Xenon Headlight assy.
Also the car will need to be version coded Xenon Present via the Star Diag aka SDS
As The Headlight (XENON) has a different Lens/projector/cut off light pattern plate inside the assy.
The aftermarket kits look cool but are not good for the light pattern also most require cutting into the wire harness and mounting the ignitor/balsat near the headlight
I Bought my OE Xenons from MBENZNL.com for the 209
Mark Cummins is online now   Reply With Quote
Old 09-17-2008, 04:10 PM   #3 (permalink)
Will 03-06 Mercedes E Class W211 OEM Headlights fit in a 2003 CLK 430 Cabriolet?
porsche911b is offline   Reply With Quote
Old 09-17-2008, 07:40 PM   #4 (permalink)
No..Different body ..different lights
Old 09-27-2008, 08:30 AM   #5 (permalink)
AsianBlackR350's Avatar
Date registered: May 2008
Not true. Please do not mislead people if you did not install aftermarket HID such as MTEC HID which requires no re program XENON present.
My aftermarket HID kit did not require re program via Star Diag. and cut off light is the same as OEM halogen projector and much brighter, BTW, no wire harness cutting, just take out the bulb and plug in the kit harness.
2008 R350 4 Matic w/P1 package/7 seater/Ipod/Front heated seats/TOMTOM Go 720 GPS/ 10.2" LCD Overhead Mobile Video system w/ 30 Sega Games, Wireless HeadPhone, hard wired to OEM HK sound system, B/U Camera, hard wired Passort Escort X8500, Mtec HID 4300k (swapped out 6000K)
2007 Acura RL w/ tech package, A-spec body kit, Deck lid spoiler,TVandNAV2go,USA spec Audio, 18 " Wheels, Wooden steering wheel, Wooden shift knob
AsianBlackR350 is offline   Reply With Quote
Old 10-07-2008, 04:15 PM   #6 (permalink)
Date registered: Apr 2008
Vehicle: 2007 CLK550 Cabriolet
This is primarily for Mark, but if anyone has anything to add, spit it out! I have an 07 550 with halogens, I bought a set of new oem bi-xenon and would like to know what is involved in making the car ready to install them, aside from the recode. I realize the bumper cover etc. must be removed, but I'm looking for info on what parts are needed to use them as active, self leveling. Mark, when you changed yours did you need any new wiring harness replacements/ splices etc to have them fully function, or did you not bother with that aspect?
Any tips or a how to will be helpful.
Thanks,
Tom
none is offline   Reply With Quote
Old 10-16-2008, 03:01 PM   #7 (permalink)
Date registered: Aug 2008
Vehicle: 2008 E350 4Matic Sports
i second that. I have a $62 kit from eBay and it works with no problem. Simple plug & play and no wire cutting, no warning lights.
2008 E350 4Matic Sport & P1 Packages
2003 M3 Convertible Fully Loaded
2001 325 Ci Premium & Winter Packages
1999 TL (One of the BEST cars I've driven!)
1998 Civic EX (Used to be heavily modified. Now plain stock except for cleared out corner lamps & Altezza Tails)
jaewchoi is offline   Reply With Quote
Bi-Xenon Upgrade from Standard Headlights benincollege W163 M-Class 1 05-08-2008 10:09 PM
[Headlights] xenon (opac) 2 OEM bi-xenon (clear) FilBen W203 C-Class 1 05-01-2006 05:57 PM
Do they make Xenon projector headlights for the 2000 ML- mine has aftermarket Xenon in the housing HACK THT W163 M-Class 7 03-25-2006 03:55 PM
Can I convert standard headlights to xenon? ecm W163 M-Class 3 09-27-2005 10:56 AM
when do u think xenon will be standard on all MB cars? cute R170 SLK Class 1 04-15-2001 02:03 AM
