Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Coupe/Convertible Forums > W209 New CLK Class
Old 08-26-2008, 03:36 AM   #1 (permalink)
StickyBenz's Avatar
Date registered: Dec 2006
Angry Sunroof Problems!!
I have 2004 CLK... I one push the Sunroof button forward - the Roof piece starts sliding forward then all sudden stops and starts sliding backwards! same thing happen when I try closing the roof with my key! All the windows close but sunroof re opens up I just cant figure it out In order for me to close the sunroof completely... I must hold down the button until it shuts. Does the sunroof close on one touch?
Oh ya Does the back window roll up one touch like the front ones do?
StickyBenz is offline   Reply With Quote
Old 08-26-2008, 04:24 AM   #2 (permalink)
cmalyan's Avatar
Date registered: Aug 2008
Vehicle: 2004 CLK320
Hi,
Try restting the sunroof ussing the following method:
1- Open the sunroof
2- Turn the ignition key off
3- Wait dor roughly 30 seconds
4- Move ignition key to position 2
5- Press the button up "To open it from behind"
6- if necessary push down hard that useless black metal "Beware not to close on your figures"
7- After it opens up from behind release and press up again for 2 seconds
8- You will hear "Tick" then the ECU will learn that the end on that position
9- Now close it normally
cmalyan is offline   Reply With Quote
Old 09-08-2008, 01:31 PM   #3 (permalink)
Date registered: Sep 2008
Vehicle: 04 CLK 500
Send a message via MSN to TalkBenz
I know exactly what this is. I just had this issue fixed. It seems that over the course of a 5 years or a bit less these sun roof gets grim and dirt build up. So you just have to clean it out very good and you should be good for another few years. I actually took mine in and it was done and they charged me next to nothing to do it.
TalkBenz is offline   Reply With Quote
Old 09-18-2008, 12:03 PM   #4 (permalink)
Date registered: Mar 2008
stickybenz, did you try any of these? or do you still have the problem?
paoylin1 is offline   Reply With Quote
Old 11-30-2008, 09:51 PM   #5 (permalink)
Date registered: Oct 2005
Vehicle: 1989 420SEL 2004 CLK500
It was happening to me too. Clean the tracks with a paper towel, then relubricate it. I didn't have any grease, so I used WD-40. Hold the button to run it back and forth past the point where it would get stuck. Mine's been fine since.
Also to double check, resynch it in case the power was lost. Just press the button to close it and hold the button shut for at least 2 seconds.
jonk is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Kotomi328
Sunroof Problems AAmais88 W203 C-Class 4 10-26-2005 03:18 PM
Sunroof Problems whitewagon W203 C-Class 5 09-12-2005 09:47 AM
Sunroof Problems Jamison W140 S-Class 12 07-01-2005 11:24 AM
sunroof problems black benz W201 190E, D-Class 3 05-09-2005 03:28 AM
sunroof problems kcbenz W203 C-Class 2 02-07-2005 06:24 AM
