Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Coupe/Convertible Forums > W209 New CLK Class
Old 08-21-2008, 12:49 PM   #1 (permalink)
Date registered: Nov 2007
Vehicle: CLK 270 cdi 2004
Arrow CLK Wont Start....
Well my new CLK is now 2 days old and ive got my first problem Car is a 2004 CLK270
Just 1 ft away from parking on my drive and the engine cuts out, Tried to start it again and it just turns over and wont fire up.
Dash displays MALFUNCTION....REMOVE KEY
Ideas?
J4GG4 is offline   Reply With Quote
Old 08-21-2008, 02:11 PM   #2 (permalink)
Date registered: Sep 2006
Vehicle: 2004 CLK 240
Hi Jagg4
Welcome to the forum - and please use the UserCP above ^^^ to add your details...
You have a CLK 270 CDI - a diesel. I'm sure a diesel owner can give you a steer on this problem. It's normal to read the fault codes for this type of fault - but you've got to get into a workshop for that. Unless you buy yourself a OBDII reader.
Here's a list of fault codes.
Mercedes Benz OBD II fault code table
keyhole is offline   Reply With Quote
Old 08-21-2008, 02:44 PM   #3 (permalink)
Thanks...
Ive left it to cool down and it still wont start.
Can you direct me in a OBD2 reader i can purchase online? Or i have a obd2 lead i used with my old audi using vag com. Can i download any software for this lead? or will this lead not work?
Finally where is the OBD2 port on the car exactly?
Many thanks
Old 08-21-2008, 06:27 PM   #4 (permalink)
Im just thinking... how accurate are the trip computer on these cars? it displays 7 miles left when i pulled up and when it conked out. I now hope it is diesel!!
Old 08-21-2008, 06:31 PM   #5 (permalink)
There's lots on eBay if you google OBD II + Mercedes. (they're not cheap)
The socket is located under your steering wheel. Look next to the red bonnet release handle to see a black plastic cover which flips down.
Old 08-21-2008, 06:37 PM   #6 (permalink)
When my low fuel warning comes on I can generally go another 25 - 30 miles. But I wouldn't rely on that Range indicator for the last few miles!
I guess you could well be out of fuel here....
Old 08-22-2008, 03:38 AM   #7 (permalink)
Thanks guys...
guess what? Im proud to be embarrased about this as im also more relieved. OUT OF FUEL. damn trip computer. The trip computer was so accurate on my old audi. oh well guess thats the end of letting her go into the reserve.
Drove my CLK under water, car wont start anymore abaja W208 CLK Class 34 08-07-2007 04:20 PM
After wire harness change temp gauge wont work, and now wont start daanmuller W140 S-Class 4 06-14-2007 09:00 AM
CLK Wont Start at All c9679 W208 CLK Class 13 05-18-2007 03:25 PM
Start, ran, wont start again horsessmellfunny W123 E,CE,D,CD,TD,TE Class 9 09-06-2006 09:58 PM
2001 CLK 320 wont start, only instrument panel, HELP oskflores W208 CLK Class 0 07-25-2005 02:48 AM
