Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Coupe/Convertible Forums > W209 New CLK Class
Old 02-12-2008, 08:19 PM   #11 (permalink)
charliew's Avatar
Vehicle: 2005 CLK 500 Convertable
How do you reset the computer for the oil change milage and also the "B" service interval milage?
charlie
charliew is offline   Reply With Quote
Old 02-13-2008, 03:18 AM   #12 (permalink)
Date registered: Sep 2006
Vehicle: 2004 CLK 240
Hi Charlie - welcome to the forum.
Details are in the Owners' handbook - do you have one? Also, could you complete your details showing us what model/year you have.
keyhole is offline   Reply With Quote
Old 02-13-2008, 09:10 AM   #13 (permalink)
charliew's Avatar
Hi Keyhole.. The manual says I have to return to dealer to have the service a & b reset!
I tried to find where to input my model CLK 500 convertable 2005. Could not figure out how to do it. Couldn't find a link to that information
Old 02-13-2008, 10:44 AM   #14 (permalink)
Date registered: Jun 2007
Vehicle: CLK 220CDi
Turn the key to position 1, press the mileage reset button 3 times and you should hear a beep. Use the up down buttons on the steering wheel to scroll through the menus. You should be able to reset the service indicator from there.
Russ
CLK220CDi
Avantgarde
rf065 is offline   Reply With Quote
Old 02-13-2008, 12:46 PM   #15 (permalink)
Hi Keyhole..
OK - at the top of the screen click on User CP. New screen appears.
At left of screen under Settings & Options, click Edit Profile. new screen appears.
Enter details here of vehicle & home location, etc.
Regarding reset, it may be 'slightly' different for your model/year. Read through this sticky on this topic
http://www.benzworld.org/forums/w209...ht-my-car.html
Old 02-13-2008, 03:01 PM   #16 (permalink)
charliew's Avatar
OK Keyhole, I have input the registration info and printed the reset procedure. Will give it a try. Many thanks. charlie
Old 03-05-2008, 06:54 PM   #17 (permalink)
Date registered: Nov 2007
Hi Keyhole,
Just bought 2003 CLK500 last summer and the mileage is 45000ml, the previous owner has given me all the service recept done on this car and the service B was done at around 43000ml and last weekend the car had 48500 ml on it and I changed the engine oil and filter. When I drained the oil and measured it, the car had 8.8 qrt and the engine level show OK. Then I filled 7 qrt of new oil and the level also show OK so now what is the correct capacity of the oil, should I add oil when the level show OK? please advise.
badinata is offline   Reply With Quote
Old 03-06-2008, 03:55 AM   #18 (permalink)
Hi badinata
When you say "the level shows OK" - is that as shown on the cluster display, or using a dipstick?
I cannot explain how you drained 8.8 US quarts. My OM says your CLK 500 oil replacement quantity is 7.5 liters, or 8 US quarts.
So 7 quarts would seem a bit short.
Old 03-08-2008, 08:55 AM   #19 (permalink)
Hi Keyhole,
On the cluster display, I think 7 quarts is the right capacity for this CLK 500 and on the cluster display shows engine oil level OK. I have an engine oil leak at the back of the engine before I changed the oil and I assume 8.8 quarts caused this leak. I will add 1/2 quarts as per your advise.
Old 08-10-2008, 06:02 AM   #20 (permalink)
fourml8r's Avatar
Vehicle: 2005 CLK55 AMG CABRIOLET
Originally Posted by JIME View Post
Do yourself a favor, save yourself a whole lot of trouble and time... Purchase a filter wrench for removal of the oil filter
along with a topsider fluid suction tool at any boating supply store...
After removal of the old filter and replacement of the new filter element and o rings...
Stick the topsider plastic suction hose down the CLK oil dipstick, pump up the topsider, open the suction valve and just let the topsider vacuum the dirty oil out of your crankcase...
Once the old oil is removed, just replace with fresh 0w40 in the case of the CLK500...
Simple proceedure, takes about a half hour and you don't even have to get your hands dirty...
This is by far the easiest way to change oil on your CLK...
i have a topsider from my old MB (SL320), now i have a CLK55 Cabriolet with no "Dipstick" so where do you suck the oil out of? Anyone have a picture or diagram?
fourml8r is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
MShawCT
DIY : Oil Change hangon W163 M-Class 44 09-19-2008 02:29 PM
Poll: mileage between oil change / brand of oil / DIY or dealer ?? Thanks! Rohf (Seattle) R170 SLK Class 27 08-05-2008 07:58 PM
DIY oil change Neb W202 C-Class 28 06-12-2008 05:18 PM
How to DIY oil change on your C230 spoons W203 C-Class 51 04-08-2008 07:29 PM
DIY Oil Change -- E420 TyBenzo W210 E-Class 23 03-17-2008 01:48 AM
