Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Coupe/Convertible Forums > W209 New CLK Class
Old 12-15-2006, 08:29 PM   #1 (permalink)
Date registered: Dec 2006
HID conversion kit for a 2003 CLK 320
i just got Mccullahs HID coversion kit for my 03 CLK320. however i'm having problems with it, my computer keeps sayin that my low beams are messed up. And they dont stay lit, always flickering. If anyone can shed some light on this for me please do. Another question, i was looking to purchase a Pioneer avicZ-1 double-dash Nav. WIll this fit in my car?
doublet034 is offline   Reply With Quote
Old 12-27-2006, 11:29 AM   #2 (permalink)
sdunham's Avatar
Date registered: Nov 2006
Vehicle: 08 ML320CDI, 05 E500, 04 CLK 500 (traded), 06 MB R350 (turned in) , 04 FORD SuperDuty King Ranch
Not an expert but also interested in the Xenon conversion for my CLK 500... Did you have the Dealer Service Dept. turn on the Xenon option after you did the conversion...? Also, what do you think of the McCullough kit...?
SMD
* SMD
* 08 ML320 CDI
* 05 E500 4-matic
* 04 MB CLK 500 (traded)
* 06 MB R350 (turned in)
* 04 F250 SuperDuty King Ranch
sdunham is offline   Reply With Quote
Old 01-09-2007, 06:47 AM   #3 (permalink)
I just had theMccullahs HID installed on my 03 clk55. works well but had the same exact problem. what you have to do to prevent the malfunctions from popping up is:
1)turn the key to the 'on' position, dont start the car just yet.
2)turn on your HID's
3)wait ten seconds
4)then start the car.
If you want to avoid all this there's a wiring kit you can get for less than $100, or like the man above said you can have the dealer activate the Xenon option, I've heard that from others as well.
r_matt_6 is offline   Reply With Quote
Old 01-17-2007, 09:25 PM   #4 (permalink)
Date registered: Jan 2007
i'm curious. how much does this kit cost?
iqzero is offline   Reply With Quote
Old 03-18-2007, 06:02 PM   #5 (permalink)
paoskie's Avatar
Date registered: Jul 2005
Vehicle: '04 C230 KSSP
Send a message via Yahoo to paoskie
hello...im curious...i also ahve the same problem...is turning on the HID for 10 seconds before starting the car actually fix the problem? are you doing this? i hope this would solve it temporarily until i can get someone to reset my computer to xenon present...the damn dealers wouldnt do it (i dont know why when its MY car) anyway, hope to hear from you
paoskie is offline   Reply With Quote
Old 03-29-2007, 11:48 AM   #6 (permalink)
Mark Cummins's Avatar
Vehicle: W211/W210wagon/W209
PM Me ..I Can get Your Car version Coded
Mark Cummins is online now   Reply With Quote
Old 04-06-2007, 11:30 PM   #7 (permalink)
Date registered: Sep 2006
Vehicle: 2003 W209 CLK 320
I heard that having HID's were illegal? is it true? I wanted to put HIDs on my CLK as well but I wouldnt want to be pulled over becuase of them. =(. I was recommended getting a single beam HID at Single Beam. Since I figure you guys might know more about it than I would...I was wondering your recommendation on that. Thanks!
nightrider89 is offline   Reply With Quote
Old 08-02-2007, 01:07 AM   #8 (permalink)
Date registered: Mar 2007
did you guys put the hid's on our stock halogen headlamps or did you change your headlamps to the xenon/projector head lamps? I am looking into changing my headlamps to projectors before getting the hid kit
0 2 60B4U is offline   Reply With Quote
Old 08-08-2007, 11:38 AM   #9 (permalink)
da_guitarist's Avatar
Date registered: Aug 2006
Vehicle: 01 CLK55
I don't know much...but supposedly the flickering comes from not taking power directly from the battery via some wiring harness. Check out HID Planet Forums (google that), and they talk about why the McCullough version flickers and how to fix it. You also might need to put a resistor in there if it says "bulb out." The xenons take less wattage, so the car thinks the light went dead b/c it isn't pulling as much wattage as before. A resistor will fix this, but I'm not sure about finding out what size.
da_guitarist is offline   Reply With Quote
HID Conversion Kit?? juank350 W164 M-Class 12 12-09-2006 05:08 PM
New 2003 ML 350 Owner...HID conversion Questions.. MLTHREEFIFTY W163 M-Class 6 09-30-2005 11:12 AM
HID Conversion Kit alee4 W124 E,CE,D,TD Class 5 09-04-2002 03:25 PM
Phillips HID Conversion Kit Guest (MBNZ) W203 C-Class 1 11-21-2000 02:37 PM
Phillips HID Conversion Kit Guest (MBNZ) W202 C-Class 0 11-14-2000 03:33 PM
