Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Coupe/Convertible Forums > W209 New CLK Class
Old 09-13-2006, 03:47 PM   #1 (permalink)
mserpe's Avatar
Vehicle: 406/280GE/240GD/G320
Help Needed! CLK 500 O2 sensors and Air Mass
I have a couple of questions about my Mercedes CLK500. The "Check Engine" light just came on last weekend when I drove to Reno and I just had it checked at a local Mercedes shop (German Auto Kraft in Belmont).
They said, apparently based on using a diagnostic code error reader, I need 4 Oxygen sensors (Two before the converter, two behind) and an Air Mass replacement. The Oxygen sensors runs $220 a piece and with labor about $1000, the Air Mass runs $380 and labor, so I'm looking at $1500 in repairs.
Question is, based on the code diagnostics how can all 5 of these items suddenly go from good to bad and trigger the check engine lamp? It does not seem like that makes any sense. Are the codes not specific enough for a shop to know which sensor exactly? It seems like the shop wants to just replace all of them instead of one at a time to see which one is bad.
thoughts????
many thanks!
Website:
www.clubgwagen.com
mserpe is offline   Reply With Quote
Mass Air Flow Sensors from FCP Groton? gregs210 General Mercedes-Benz 0 12-15-2005 12:10 AM
$500 to replace air mass meter reasonable? uncS4 R170 SLK Class 6 06-28-2005 03:34 PM
clk Air Mass Sensor replacement juancpath W208 CLK Class 10 05-07-2005 08:26 AM
Mercedes-Benz ML-Class Air Mass Sensors W163 M-Class 0 07-09-2003 02:34 AM
Mercedes-Benz E-Class Air Mass Sensors W210 E-Class 0 07-09-2003 02:34 AM
