I have a question, does anybody know how to remove the headlamp from a CLK500 Coupe 2002?
I found and removed the 2 upper screws but something is holding it from under, I can`t seem to figure out what it is, is it a screw or something else!?
I have the same problem, but as I have 2 headlamps on my bench ready to go in I know there is a 3rd fixing which goes to the wheel arch.
I've had the plastic shields in the wheel arch off and as best I can tell, the fixing is through the button that locates the fork attached to bumper.
it comprises of a threaded insert in the headlamp (unlike the other 2 which are clearance holes)which may have a bolt in it or perhaps a locating pin as it is loose, however try as i may I can't get the unit out and I can't see the fixing without removing the bumper, which I'm loath to do.
Is ther a body shop member who can throw more light on this, olease.
