2006 CLK 350 battery removal? - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 09-23-2012, 07:56 AM Thread Starter
Date registered: Sep 2012
Vehicle: 2006 CLK350, 2003 BMW 325Ci, 1969 Buick Skylark
Hey everyone Im new to the board and had a question. I've had my 2006 CLK 350 for about two years and recently had it serviced by the dealer. They told me that there was a short in my battery and it needed to be replaced. I wasnt going to pay the dealer to do something I could do myself. So I went to remove the battery yesterday and it wont budge! I snapped one of the handles trying to pull the battery out. Is there a hold down bolt somewhere? For the life of me I could not see anything else holding the battery down.
Nuttzo is offline
post #2 of 7 (permalink) Old 09-23-2012, 09:18 AM
rudeney's Avatar
Date registered: Dec 2004
Vehicle: CURRENT: 2007 CLK550 Cabriolet, 2002 C240 FORMER: 2001 ML320
Quoted: 145 Post(s)
Yes, there is a hold down that has to be loosened. Standing in front of the vehicle, it's at the base of the battery, on the right side. You'll need a very long extension to get to it.
- RODNEY
rudeney is offline
post #3 of 7 (permalink) Old 09-23-2012, 09:21 AM Thread Starter
Appreciate the info rudeny, thanks.
Nuttzo is offline
post #4 of 7 (permalink) Old 09-23-2012, 10:33 AM
Red,'s Avatar
Date registered: Feb 2008
Vehicle: W209 CLK500 & W220 S430
Remember to connect a solar charger or jumper to your power port . . .
Then you won't have to reset everything !
Red, *<(:{)-
1999 Prostar West Super Gas Champ.
2000 NMRA/Prostar E/T #2
2001,'02,'03 NMRA E/T Champ.
2004 #3, 2005, & 2006 NMRA E/T #2
2007 Pro St. Legal #6, NMRA Pro E/T Champ.
2008 Motorcycle Drag Racing Assoc. SS Champ.
Red, is offline
post #5 of 7 (permalink) Old 09-23-2012, 06:11 PM
rudeney's Avatar
Quoted: 145 Post(s)
I STRONGLY discourage the use of those "setting savers" as they have been known to cause more problems with fried SAMs and such. With the battery disconnected, you have three functions to reset: the clock, the auto-close function on the windows ans sunroof, and the steering angle sensor for ESP. The clock is set via the MFD and steering wheel buttons (or on COMAND if you have NAV). To reset the auto-close functions, just open each windows and the sunroof halfway, then close each one, and hold each button an extra 5 seconds once the glass is closed. To reset the steering angle sensor (and it doesn't always need it - only if you get an error) then start the engine and turn the steering wheel fully lock to lock twice. You won't lose your seat memory or radio presets.
Oh, and I poked my head under the hood to check - there are two bolts you need to loosen - just look on the right side of the battery and you'll see them.
- RODNEY
rudeney is offline
post #6 of 7 (permalink) Old 08-22-2013, 05:06 PM
Date registered: Mar 2009
Quoted: 6 Post(s)
battery vent tube
Hi there. I just replaced the battery on my CLK320 2004. I put the new battery in place but forgot to insert the battery vent tube. One end of the tube goes into the battery; what about the other end? Is there a hole in the car body near the battery to insert that tube? I totally forgot to see that before putting the new battery in place and the battery is really tight in the location. There's no much room left around the battery to check. I'm asking before taking the battery off again because it is heavy. Can someone tell me about that? Thanks
fernmc is offline
post #7 of 7 (permalink) Old 07-20-2014, 12:44 PM
Date registered: Nov 2012
Vehicle: 2005 CLK320 coupe
Longest life battery I've ever had
The other end of the vent tube doesn't connect to anything - it just exhausts below the battery (at least mine wasn't connected to anything). I just replaced my OEM battery with another from the dealer ($147 w/15% discount) - this was a NINE year old battery that was the original! And this car has been in the heat of Las Vegas for its entire life - I've never had a battery last this long so I didn't tempt fate and got another OEM!
RadicalModerate is offline
  Mercedes-Benz Forum > Mercedes-Benz Coupe/Convertible Forums > W209 CLK Class
User Tag List
