2004 CLK 500 oil leak - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 03-08-2011, 06:16 AM Thread Starter
Date registered: Aug 2010
Oil leaks right from under the oil filler, does this look like a cylinder head/valve cover gasket issue? pics attached. 1st pics is the the area cleaned with brakleen, 2nd shows where the oil is coming from. car has about 60k miles. I'm new to Benz's so any info appreciated.
ID:	361585   Click image for larger version
martinCLK is offline
post #2 of 5 (permalink) Old 03-08-2011, 11:43 AM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 248 Post(s)
It seems to me that all that is happening here is a slight leak at the flange where the oil filler is mounted onto the cylinder head cover. Have you tried tightening up the bolts that are showing in the pic?
The gasket under the cylinder head cover appears to be good....Not a major problem here, imo.
keyhole is online now
post #3 of 5 (permalink) Old 03-08-2011, 12:21 PM Thread Starter
thanks for the feedback, i did try to tighten the bolts a bit and i think the oil seepage has slowed. I'll try and tweak it a bit more.
post #4 of 5 (permalink) Old 03-08-2011, 03:00 PM
keyhole's Avatar
Quoted: 248 Post(s)
Go easy!
It's well known that folks often strip the threads on the cylinder head (valve) cover bolts through overtightening. This is into the same soft material.
Why not do the reverse, and undo the bolts to examine why the flange is leaking. Is there a paper gasket there? Maybe replace it and use the right sealant when it is refitted.
post #5 of 5 (permalink) Old 03-08-2011, 05:39 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 34 Post(s)
Rather than tweaking, remove and reseal. That's fairly common for the modular engines.
Check Codes is offline
  Mercedes-Benz Forum > Mercedes-Benz Coupe/Convertible Forums > W209 CLK Class
User Tag List
04 CLK 500 oil leak from oil filler are martinCLK W209 CLK Class 9 03-09-2011 04:31 PM
2004 mercedes c240 oil leak brandomatic W203 C-Class 11 03-20-2009 01:03 PM
2004 CLK 500 Blue ZR1 General Mercedes-Benz 0 01-28-2009 07:53 PM
HELP PLEASE ... 2004 CLK 500 castello48 W209 CLK Class 2 11-13-2008 09:07 AM
HELP PLEASE ... 2004 CLK 500 castello48 W209 CLK Class 0 11-12-2008 09:56 PM
