2005 CLK 320 MERCEDES CONVERTIBLE LUGGAGE PARTITION STUCK - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 03-16-2009, 09:48 AM Thread Starter
Date registered: Mar 2009
Help, my soft top wont go down. I get a message to close the trunk partitioner but it won't latch, any suggestions? Thanks
zmama is offline
post #2 of 3 (permalink) Old 04-29-2009, 03:27 PM
charliew's Avatar
Vehicle: 2005 CLK 500 Convertable
There is a latch with a switch on it that closes when the partitioner is in place. Access is best by partially opening the top so that the rear deck is opened up. Pull the partition to the rear paying attention to the driver side where the latch/switch is located. You can hear/feel the switch being made. Then do the partial opening of the rag top.
On mine, a plastic pin on the passenger side broke off keeping the partition from functioning properly. I am getting a new pin from the dealer soon, so I will let you know then.
Charlie
charliew is offline
post #3 of 3 (permalink) Old 09-07-2009, 05:10 PM
Date registered: Aug 2009
Vehicle: 2006 CLK350 Cabriolet White/Stone
I am experiencing the same problem. Top had been working fine and I never had a need to fold the luggage divider into the forward position. All of a sudden I get this message "please close luggage divider" or something like that. The top would not go down. When I pulled the bottom of the panel toard the rear of the car and listened carefully, I could hear the limit switch make. But when I release the divider it moved slightly forward and I could hear the limit switch click again. When the panel is pulled toward the rear the two gas struts extend but are not pushing hard enough to hold the partition against the limit switch. If there is some other latching mechanism that is supposed to hold the panel in the down position I cannot find it. Have others had this problem and what was the solution - replace the struts? Thanks, Russ
Russ White is offline
  Mercedes-Benz Forum > Mercedes-Benz Coupe/Convertible Forums > W209 CLK Class
User Tag List
2006 CLK-500 Convertible Cabriolet Top Problems:Close Trunk Partition Error Code Tomcat715 W209 CLK Class 7 04-19-2014 07:50 PM
CD Changer Problem - Disk 4 Stuck - 2005 CLK 320 paulfinkle Audio & Telematics Forum 9 06-17-2013 05:39 AM
CD Changer Problem - Disk 4 Stuck - 2005 CLK 320 paulfinkle General Mercedes-Benz 3 03-04-2008 05:54 AM
FS: 2005 CLK 500 Mercedes Convertible Kevin M. For Sale/Wanted/Trade/Giveaway 0 06-12-2007 04:24 PM
2005 clk 320 convertible weiand9 W209 CLK Class 1 05-12-2005 05:08 AM
