» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Coupe/Convertible Forums > W209 CLK Class
Old 12-10-2008, 06:44 PM   #1 (permalink)
Date registered: Dec 2008
Convertible not working - Please help
I recently bought a 2006 clk320 convertible but the the top wont come off. I took it to the benz dealership and they told me its the wiring and will cost me 3k. I am not a novice to wiring so I wouldnt mind fixing it myself if there are any DYI diagrams or anything regarding this. Any help would be appreciated. Thanks!
arram is offline   Reply With Quote
Old 12-11-2008, 09:34 AM   #2 (permalink)
Date registered: Oct 2008
Send a message via Yahoo to NAPTOWNBENZ
mm....did they more more of an indepth diag. There is wiring in the rear trunk area that gets "crimped". There are also hydraulic lines that leak and lose pressure . I will do a little research here and see what history we have.
Shawn
Mercedes-Benz of Annapolis
www.getmercedesparts.com
NAPTOWNBENZ is offline   Reply With Quote
Old 12-11-2008, 07:36 PM   #3 (permalink)
Date registered: Nov 2008
Just curious. Could be a stupid question. Is there manual mode? I have a Nissan convertible and there's a knob on top of the pump that I can turn. Once it's turned, I can manually open and close the top. Well, I'm sure it'll be a pain to do that even if manual mode works on clk.
06_clk350 is offline   Reply With Quote
Old 12-11-2008, 07:54 PM   #4 (permalink)
Date registered: Sep 2004
Vehicle: 2006 Silver CLK350 Cabriolet
Send a message via Yahoo to sfguy100
Post Should Still be Under Manufacturer Warantee
If you have less than 50K miles and a 2006 the car should be still be under the original manufacture 48mo/50K mile original warrantee.
sfguy100 is offline   Reply With Quote
Air Vents stop working, bang on passenger side dash board and it starts working... realog W202 C36 AMG, C43 AMG 2 10-12-2008 01:15 AM
W124 Convertible Not Working!!!!!!!!!! toni_perotti W124 E,CE,D,TD Class 30 04-17-2008 05:40 PM
I GOT AN 04 CLK320 W209 CONVERTIBLE OVER THE R171 SLK350 & SLK280 CONVERTIBLE !!!!!!! max_benz R171 SLK Class 5 10-24-2007 12:18 AM
It is working!!! Modular Control System is not working after I changed battery di_mb W163 M-Class 0 12-27-2006 07:04 PM
Speedmeter working but odometer not working 300SE W126 S,SE,SEC,SEL,SD,SDL Class 2 05-23-2006 07:45 AM
