» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Coupe/Convertible Forums > W209 CLK Class
Old 07-20-2008, 03:37 PM   #1 (permalink)
Date registered: Jul 2007
Vehicle: '04 E320 4Matic Wagon, '95 E300D, '77 6.9, 05 CLK320 Cabriolet
intermittent AC operation in stop and go...
driving.. no issue at freeway speeds.... I am referring to cold air not a problem with air flow. thoughts?
harriscommissioner is offline   Reply With Quote
Old 07-20-2008, 05:35 PM   #2 (permalink)
79Mercy's Avatar
Date registered: Oct 2006
Vehicle: 1979 280CE
look and see if the clutch is cutting in and out while it is idling.
'79 280CE with 216,400 miles
'76 300D with 183,100 miles
79Mercy is offline   Reply With Quote
Old 07-22-2008, 11:40 PM   #3 (permalink)
unitfreebie's Avatar
Date registered: Oct 2007
Vehicle: 2006 CLK 350
Post Cool but not ICE cold!!!
Yes.. do the above post check... and also could be low on R134a as in stop and go the engine rpm is lower causing the compressor pressure to fall below the pressure cut off limit... thus cutting off the compressor.
Put a thermometer in the center vent... if it does not read 60 degrees F at idle or 50 degree F at 1500 rpm, then add a can of refrigerant to the low side of the AC system.
If you have the AC gauges.. the low side should read about 25-30 psi and around 150psi on the high side. If the low side reads lower than 25 psi, then add a can to bring it up while watching the temperature gauge drop as the can is added to the system.
Good Luck ..
: MBZ 280E, 260E, 300SD
MBZ 190E, E320W, CLK350
unitfreebie is offline   Reply With Quote
heat/ac blower intermittent operation W124_fan W124 E,CE,D,TD Class 2 03-11-2008 07:44 PM
SLK 200 intermittent stop K40 relay dvosges R170 SLK Class 10 04-05-2006 07:21 AM
Intermittent Light Operation 92300CE W124 E,CE,D,TD Class 3 11-02-2005 11:25 AM
Intermittent stalling while slowing to a stop (300TE) 67_250SE W124 E,CE,D,TD Class 3 10-27-2005 06:57 PM
Operation Stop Leak BrianDHuff W202 C-Class 0 08-24-2005 07:05 PM
