» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Coupe/Convertible Forums > W209 CLK Class
Old 07-19-2008, 05:29 PM   #1 (permalink)
Date registered: Apr 2007
Vehicle: CLK Coupe 03 270 CDI
Cruise Control Problem
I am having a problem with my cruise control in my 2003 CLK 270 CDI. It does not seem to work between the speeds 67-76 mph. It engages for a second and then deactivates itself. However the cruise control work at all other speeds. Does anyone have any idea why this may be happening and how I would be able to fix it?
Thanks!
bhavick is offline   Reply With Quote
Old 07-23-2008, 01:44 AM   #2 (permalink)
unitfreebie's Avatar
Date registered: Oct 2007
Vehicle: 2006 CLK 350
Post To Vacuum or not to Vacuum... that is the question?
Check for a vacuum leak!
: MBZ 280E, 260E, 300SD
MBZ 190E, E320W, CLK350
unitfreebie is offline   Reply With Quote
Old 07-23-2008, 01:59 AM   #3 (permalink)
Unhappy To Cruise or not to Cruise.... that is the question!!!
Actually, the most probable cause is a bad cruise control amplifier... if you can borrow a good one to try out and see if that fixes your problem.
also for what's it worth ... from another forum... here's a reason why the CC amp goes bad:
...."It sounds like your cruise amplifier is going belly up -- common enough. The main reason that cruise amps go bad is improper replacement of brake light bulbs. If American bulbs are used to replace the original German bulbs, an improper current is sent to the amp when you hit your brakes. This eventually burns out the unit." ....
Can anyone comment on the truth of the above statement???
cruise control problem qtstorm W124 E,CE,D,TD Class 1 09-05-2005 08:11 PM
Cruise control problem dlbehrns W208 CLK Class 0 08-18-2005 09:40 PM
Cruise Control Problem erc22 W201 190 Class 5 11-04-2004 04:01 PM
Cruise Control Problem DUTCH G-Class 20 08-02-2004 06:45 PM
Problem with Cruise Control Guest (MBNZ) W201 190 Class 7 09-22-2002 08:42 AM
