» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Coupe/Convertible Forums > W209 CLK Class
Old 07-08-2008, 04:51 AM   #1 (permalink)
Date registered: Jul 2008
Exclamation how to change us radio frequency to european?
hi
i bought mercedes c class 2005, clk 2007 and gl 2008 and id like to know how to change us radio frequency to european (90.0, 90.1, 90.2, 90.3, etc)any idea how to convert it? please help.. thank you!
jachub is offline   Reply With Quote
Old 07-13-2008, 06:23 AM   #2 (permalink)
Originally Posted by jachub View Post
hi
"14. Whats the difference between US and European COMAND systems?
They seem to be the same hardware with different software. US systems do not support RDS text, they use US frequency spacing between stations on FM/AM radio, they support satellite radio and the TV button is blanked out (although can be enabled by the dealer). You can install a European system in a US vehicle, then you get RDS. It should be possible for the Mercedes dealer to configure ('code') the Comand using their star diagnosis workshop computer to tell it to use US frequency spacing for the radio. I'm not convinced that Teleaid will work on European Comand systems installed in US vehicles so you should check that it does."
This is a quote from mercupgrades.com/COMAND+FAQ-faq-1.html#14
I have doubts that it will work - possibly the site is referring to Becker comands and not Alpine. Bye the way, having imported a '05 CLK to Europe I am facing the same issue. So far I haven't gone to see the dealer.
USCLK05 is offline   Reply With Quote
how to change us radio frequency to european in mercedes? jachub W203 C-Class 1 07-08-2008 09:00 AM
Radio Frequency Change datax Audio & Telematics Forum 3 04-01-2008 01:30 PM
noise in radio frequency bzprince W140 S-Class 10 02-20-2008 09:32 AM
Radio Frequency problem CYP R170 SLK Class 1 12-23-2006 08:06 PM
Radio frequency change, hesitating performance and mirror memory Jexpert W163 M-Class 0 08-29-2006 02:17 PM
