» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Coupe/Convertible Forums > W209 CLK Class
Old 06-07-2008, 09:13 AM   #1 (permalink)
unitfreebie's Avatar
Date registered: Oct 2007
Vehicle: 2006 CLK 350
Angry HELP!!! How does the head rest come off??
OK, I tried everything including yanking up on the headrest to get it off the seat, but it will not budge.
I do see any locking holes at the base of the slide rails or hidden buttons on the back of the seat that would release the guide rails...
How does it come off???
: MBZ 280E, 260E, 300SD
MBZ 190E, E320W, CLK350
unitfreebie is offline   Reply With Quote
Old 06-07-2008, 10:57 PM   #2 (permalink)
Date registered: Feb 2008
Hammer Hammer
ramsey9000 is offline   Reply With Quote
Old 06-08-2008, 04:10 AM   #3 (permalink)
Unhappy How do you disassemble the back of the seat??
Waaa? Did you ever try to hammer a pillow??? Where do you hit it??
Is there a release somewhere... or do you have to disassemble the back of the seat to release the head rest guide rails? If so, how do you take the back off?
Anyone, please ???
Old 06-08-2008, 06:37 AM   #4 (permalink)
Diesel Benz's Avatar
Vehicle: 221.122 & 212.025 & 204.089
If you fold the backrest forward, you should find two screws at the bottom, one at each side.
The lining has two hooks at the top, you have to slide it downwards until the top comes off.
Diesel Benz is online now   Reply With Quote
Old 06-08-2008, 11:04 AM   #5 (permalink)
79Mercy's Avatar
Date registered: Oct 2006
Vehicle: 1979 280CE
I loked at EPC and it shows a wrench for the headrest. Now weather or not you need it to remove the headrest I don't know.
'79 280CE with 215,700 miles
'76 300D with 181,400 miles
79Mercy is offline   Reply With Quote
Old 06-08-2008, 11:14 AM   #6 (permalink)
Thanks for the backrest panel removal !!!
I just hope once I get in there, it is obvious how to release the headrest!!!
But you never know... these clever Germans!!!
A wrench for the headrest?? I'm as clueless as you as to the meaning... can anyone enlighten us?
Old 06-08-2008, 12:07 PM   #7 (permalink)
79Mercy's Avatar
Vehicle: 1979 280CE
I just got my manual out, it says to raise the headrest up as far as it will go and then pull it out.
Old 06-08-2008, 06:44 PM   #8 (permalink)
Unhappy Active Head Restraints are not removeable !!!
Hey Guys,
Thanks for all the help... as it turns out I have Active Head Restraints!!! That means they cannot be removed.
I will have to do what Diesel Benz said ... remove the back panel of the seat and disconnect wires and whatever???
Does anyone have the procedure what to do once inside the back of the seat?
Old 06-08-2008, 07:06 PM   #9 (permalink)
79Mercy's Avatar
Vehicle: 1979 280CE
What is a "active" headrest?
Old 06-08-2008, 09:09 PM   #10 (permalink)
Post Active Head Restraint for Rear-End Collusion...
Active Head Restraint works in a rear-end collusion... to prevent head and neck injury when the head is thrown forward and then backwards.
The head rest is locked in it's most forward position during a rear-end collusion, so that the head has less distance to travel before it contacts the head rest.
After the collusion, the head rest must be RESET with a tool.
Because of that, the head rest cannot be removed from the seat. There must be a solenoid with wires going down the guide rail tube.
You learn something new about your car every day!
Headrest redbeast R129 SL Class 13 11-22-2008 01:33 PM
head rest z168 W201 190 Class 6 04-05-2008 01:36 PM
Head Rest Curacao W202 C-Class 2 02-29-2008 01:54 PM
Head Rest sangsangpub For Sale, Trade & Wanted Items 1 12-06-2005 06:30 PM
Head rest problem taeandji W210 E-Class 5 02-21-2004 05:45 PM
