» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Coupe/Convertible Forums > W209 CLK Class
Old 06-01-2008, 10:58 AM   #11 (permalink)
Mark Cummins's Avatar
Vehicle: W211/W210wagon/W209
Originally Posted by goliath27 View Post
Mark, know how much a wheel would go for? about?
I Think a ECU reflash or mod would help you more in the shift points.
ALi
I Have a AMG Manufactur Alcantera / Leather Steering wheel with Raised Thumbs WITH Paddle shift as It was a Special order from AMG then I Upgraded the paddle shifters to the tall metal paddles
You should be able to get a stock AMG wheel on Ebay.DE (german Ebay except the exchange rate on our dollar is WEAK
Mark Cummins is online now   Reply With Quote
Old 06-01-2008, 12:47 PM   #12 (permalink)
Date registered: Aug 2007
Vehicle: 2003 CL500
Mark, would you happen to know of any junkyards I can find a Alcantera headliner at? This Beige Headliner is KILLING me to look at. Everything inside my car is black except that and its just off. Inside the C300 loner the dealer gave me, its black and I'm damn envious.
ALi
goliath27 is offline   Reply With Quote
Old 06-01-2008, 01:22 PM   #13 (permalink)
unitfreebie's Avatar
Date registered: Oct 2007
Vehicle: 2006 CLK 350
Exclamation Paddle Shift VS. Transmission Shift, that is the ???
Hi Mark,
Thanks very much for the info but to clarify so I can get the picture....
1. How do you like shifting with the Paddles vs. Transmission +/- knob?
I
2. Is the shifting lag identical for both Paddle and Transmission controls? Or does the Paddle shifting use a different set of firmware routine compare to the transmission firmware routine?
3. Does flashing the TCU firmware eliminate the shift lag for both shift methods or does it just move the shift point for each gear speed.
4. Does the Paddle shifter wiring harness plug into the new horn ring which then plugs into the Black 3 wire socket in the steering wheel? The only other connector I see is the multi-pin socket that has the two air bag cables.
If the Paddle shifter and Horn button are connected to the new horn ring and plugs into the 3 pin socket, then that means the horn and paddle signals are multiplex by an integrated circuit to the computer; and there is no direct wire connection to the TCU.
5. Do you recall the approximate cost of the New Horn Ring?
Thanks again for all your help ..
: MBZ 280E, 260E, 300SD
MBZ 190E, E320W, CLK350
unitfreebie is offline   Reply With Quote
Old 06-03-2008, 09:58 AM   #14 (permalink)
ALi
I Dont think that you will find a Black Alcantera Headliner in a Bone yard..Just have yours recovered
As our 209 has the SPORT option it has a Black Headliner and all the items..visors/lights/switch assy are all black
Old 06-03-2008, 10:03 AM   #15 (permalink)
Originally Posted by unitfreebie View Post
Hi Mark,
I
1 The paddle shift is a lot easier on the wheel vs the shifter on the console
2 Its the SAME
3 IF You can find a software upgrade for the TCU ..Then It will move the shift points up..like the AMG Speed shift ..and NO they cannot be swapped to a NON AMG car
4 Like I said before it is NOT Plug and play the contact ring is DIFFERENT and the Wires are DIFFERENT...But yes it can be done It requires a different contact ring assy
5 I Do not remember the P/N or the prices as Several Items were done at that time
it cant be that bad...
Old 06-03-2008, 01:20 PM   #16 (permalink)
Vehicle: 2003 CL500
Problem happens with re-doing it is the Airbag covers. Might just end up selling it and looking for a better more reliable car instead
ALi
Old 06-04-2008, 04:40 AM   #17 (permalink)
A Paddle Shift Project ... any volunteers???
Hi ALi,
Guess I am lucky... everything in my CLK350 is all black! I thought that was maybe too dark but I'm beginning to see your viewpoint.
Hi Mark,
Thanks for all your good experience... I now have a pretty clear picture of the Paddle Shift MOD you did. AND how it all works.
1. The Paddle Shift and Transmission Shift are identical in speed and shift points; only the convenience of the Paddle Shift has the advantage.
2. Flashing the TCU firmware only changes the Shift Point of the transmission, NOT the shift SPEED... so the shift lag problem is not improved, and will just have to live with it unless you get an AMG transmission transplant?
3. The Steering wheel MOD can be done with all factory parts for a price. AND requires the dealer to activate the Paddle Shifter via the STAR computer.
Well, I have a nice Burl wood steering wheel that I really like, so I don't want to change it ... I did find two styles of Mercedes Paddle Shifter switches: a tall aluminum and a shorter black plastic switches which are priced at $185 and $115 respectively.
I would tend to go with the shorter black plastic paddle shifter switches since it will match my car's interior and would be less likely to be hit accidentally when turning the steering wheel. But the only drawback is that it would require some "dremmel" work on the steering wheel base to mount the switches with a single screw.
Then once the switches are mounted, then the wires can be run down the steering wheel column and over to the transmission +/- switches and wired in parallel.
I still have to figure out how to get the paddle switch cables out of the steering column (hopefully there is a hole somewhere!) and then find a path to snake it back through the transmission tunnel cover to the shift knob switches; it would be wise to add a disconnect connector in the cable between the steering wheel and transmission tunnel so that everything can be disconnected incase of a problem. Also maybe someone who has had the car apart before can tell me if there might be an easier way to route the wires?
So comments or anyone want to help me do this project?
Old 06-05-2008, 07:19 PM   #18 (permalink)
Vehicle: 2003 CL500
LOL Lucky fucker lol. Looking to get into something different now, just not sure as to what?
ALi
Old 06-05-2008, 11:33 PM   #19 (permalink)
Yes, guess I am lucky... All Black is BAD ...
Well, I really like the CL500's series but when I went over to that forum and checked it out... seems that it has way too many problems for a >$100,000 car!
I don't mind some problems because these are a Mercedes .. just like little babies... but if it acts like a teenager with an attitude, I can do without it!
Do you really need such a big car? I went from small to big and now back to small (CLK) as they kids are all in college and out of the house; we do mostly city driving.
The new E350 sport is very nice, but is a 4 door.
I like the CLS style a lot but don't want the 8 cylinder engine... I would consider it with a V6 like a CLS350.. or even a CLS diesel! It's probably availabe in Europe but not here in the States.
When is Mercedes coming out with a Hybrid?
There is a very nice BMW 3 series hard top convertible that looks good too.
The economy is really bad now and all high end cars are taking a good hit in resale value.
Mercedes just emailed me with a big clearance sale... things are getting tough!
Maybe you can be the first one to get the TaTa from India?
Old 01-06-2009, 06:39 AM   #20 (permalink)
Date registered: Dec 2008
Hi Mark,
I just bought an e55amg wheel (with the buttons), not the beautiful alloy paddles, . Can I have the buttons working on my 2003 W211 E240?
How would I do this please?
Regards
Areez
ap10046 is offline   Reply With Quote
Replacing 2006 Paddle Shifter with the 2007/08 ones? NYSLK55AMG R171 SLK Class 8 03-29-2009 07:58 AM
4Matic VS Paddle Shifter rs1985 W204 C-Class 3 05-09-2008 10:36 AM
paddle shifter HwoALanG R171 SLK Class 21 04-08-2007 09:15 PM
paddle shifter SILVERBOX G-Class 1 01-07-2006 02:33 PM
Hows do you like the paddle shifter on the auto t xJagman R171 SLK Class 22 08-11-2005 07:15 AM
