» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Coupe/Convertible Forums > W209 CLK Class
Old 05-11-2008, 07:46 PM   #1 (permalink)
nderevj's Avatar
Date registered: Mar 2008
Vehicle: 2005 CLK500
CLK500 Audio - Command Tips/Tricks?
I just purchased a 2005 CLK500 and have been playing around with it's audio system. So far I'm very impressed with the Command System but have two questions:
1) Are there any after market gadgets that will boost the antenna? There are a few stations that no longer come in as clear as my last car.
2) Are there any websites or even forums (perhaps this one?) regarding Tips, Tricks, Hacks, Firmware Updates, Nav DVD updates/purchases, etc related to the Command System?
Thanks all!
nderevj is offline   Reply With Quote
Old 05-11-2008, 07:59 PM   #2 (permalink)
Date registered: May 2008
Yes, there are updates that a dealer will perform under warranty. I used to be a tech for a few years and came across with the problem a few times. The antenna is fine and please don't touch. If your antenna was bad, you would have problems with all the stations. If the nav antenna was bad the nav system would fail. The dvd that the dealer can install takes a few minutes to install and fixes a bunch of problems. Keep in mind that if you replace the navigation dvd with a newer version, you cannot use the old one again. Its a mistake that can cost about $300 By the way, there are updates for both the comand and the navigation system
Sovereignbenz is offline   Reply With Quote
Old 05-17-2008, 12:52 AM   #3 (permalink)
nderevj's Avatar
Thanks Sovereignbenz for the advise. But I'm not clear about the update. Are you not recommending the DVD update? Also, is there a way to find out what the update actually does- feature/fix list?
I thought I read somewhere that you can play MP3's, is that true is do you need something after market or hacked? Anyone know?
Any other tips?
Tips & tricks ScottinSoCal R/C107 SL/SLC Class 15 04-09-2008 01:57 PM
tips and tricks wuzoo Detailing and Car Care 4 06-30-2006 09:13 AM
MCS Tips & Tricks??? TheOgre W163 M-Class 8 09-16-2005 12:43 PM
Other tips and tricks? ChicagoE320 Audio & Telematics Forum 0 12-08-2003 10:54 PM
Websites for tips and tricks?? Norseman W210 E-Class 6 05-16-2003 04:16 PM
