» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Coupe/Convertible Forums > W209 CLK Class
Old 05-02-2008, 09:44 PM   #1 (permalink)
robinp's Avatar
Date registered: Feb 2004
Vehicle: 300SL-24V/CLK 200 /Toyota Harrier
CLK convertible-- Top problem
HI ,
I've got a clk convertible.
I press the key 3 times and hold on the button . The top starts to move but stops when the back moves up .
Any idea ?
Please advice>>>>
Thanks
robinp is offline   Reply With Quote
Old 05-06-2008, 04:55 PM   #2 (permalink)
Date registered: Mar 2008
The keyfob is infared so you have to point it directly at the door handle, I had the same problem as I initially figured the signal was radio and so was moving around with the key fob, if you are not aligned with the IR beam the roof stops.
treller is offline   Reply With Quote
Old 05-06-2008, 11:50 PM   #3 (permalink)
Date registered: Nov 2007
Vehicle: CLK320 Cabriolet 2004 (A209) in Obsidian Black with two tone grey leather.
Treller is right. Whilst you can lock and unlock the car from the next field, you can only open/close the roof whilst standing next to the drivers's door and pointing the key at the car. Must be a "safety" issue, to ensure you don't trap anyone in the folding roof!!!
DougCLK320 is offline   Reply With Quote
Convertible top tilting problem beachlivin W208 CLK Class 6 06-22-2007 09:28 AM
Convertible top problem mcsmbilt_357 R129 SL Class 1 10-18-2006 07:04 PM
Faulty Convertible Top Switch - 1999 CLK Norm! W208 CLK Class 6 04-30-2006 04:00 PM
SLK230 Convertible top problem HighPoint General Mercedes-Benz 3 09-23-2005 08:00 AM
CLK convertible top finally works Steve W208 CLK Class 1 10-05-2003 03:19 PM
