» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Coupe/Convertible Forums > W209 CLK Class
Old 04-29-2008, 03:48 AM   #1 (permalink)
Date registered: Nov 2006
Vehicle: CLK 200 Cabrio
Upgrade ECU of CLK 200?
Hi All,
My dealer is offering a free ECU mapping of my 2006 CLK 200 that will increase HP from 163 to 184.
What are the pros and cons?
Should i go for it?
What would you do?
Thanks
P
padamou is offline   Reply With Quote
Old 04-29-2008, 08:41 PM   #2 (permalink)
Mr_Ferrari's Avatar
Date registered: Feb 2004
Vehicle: 2005 CLK200 Komp, 2007 R350
Why wouldn't you want to do it? I'd do it if my dealer offered it.
Current Rides:
2007 R350 SWB
2005 CLK200 Kompressor
1989 MR2 Turbo
Gone but not forgotten:
1995 Skyline R33 GT-R V-Spec
1998 SLK230 Kompressor
2003 C180 Kompressor Sports Coupe
Mr_Ferrari is offline   Reply With Quote
Old 04-29-2008, 10:22 PM   #3 (permalink)
unitfreebie's Avatar
Date registered: Oct 2007
Vehicle: 2006 CLK 350
Thumbs up
Do you have smog emission laws over there in Cyprus?? If not, then GO for it..
: MBZ 280E, 260E, 300SD
MBZ 190E, E320W, CLK350
unitfreebie is offline   Reply With Quote
Old 04-30-2008, 01:11 AM   #4 (permalink)
Thanks for your answers guys.. No issues with emissions here...!!
I guess i am wondering if i should be aware of any issues if anything can go wrong etc etc.
Thanks
P
Old 04-30-2008, 01:49 AM   #5 (permalink)
Post
Do you know any Automotive Electronic Geeks over there??? You could pop open the "Brain" and see if the Firmware chip is in a socket; if it is you can pop it out and "copy" it and save the copy as the original version.
Then when the Dealer upgrades the chip to the new firmware you will also have the old firmware chip copy to fall back onto if something goes wrong or you don't like it.
Old 05-02-2008, 10:55 AM   #6 (permalink)
I am in negotiations with them to get it done for Free (i might have to pay some amount after all )
Under these new circumstances, the questions i have are:
1. Will the ECU remapping alone be enough to bring the 163 BHP to 184?
2. Will there be more fuel consumption when driving "normaly"?
3. Will there be a noticeable difference (worth paying for)?
Thanks
P
Old 05-13-2008, 11:40 AM   #7 (permalink)
p-1
Date registered: May 2008
Thanks
P
1. yes
2. most of the time
3. yes
Most of the time at least here in the states manufacturers detune their cars to 1 pass emissions 2 save wear and tear on parts drive trains and what not. Most simple remapping just adjust the timing and other simple changes. So when when you get on it your going to use more gas then before but for just cruising you shouldn't see much if any increase in fuel consumption. I actually saw an increase when I had my truck done. Its def worth doing. If you don't like it you can always have the stock program put back on. Or you can do what I did and buy and additional pcm and have them tune that one and keep the stock to switch back and forth. Hope that helps you a bit.
p-1 is offline   Reply With Quote
InMotion ECU upgrade for $200...feedback? deyainrdy4ds W208 CLK Class 5 03-07-2007 01:47 PM
ECU Upgrade Markdm3 W219 CLS Class 0 06-17-2006 05:47 PM
ECU upgrade Joe R170 SLK Class 9 02-25-2002 08:41 PM
For those who wonder is there away to get more "FUEL" for Clk without upgrade ECU. The answer..YES! Linh W208 CLK Class 13 10-19-2001 08:31 PM
ecu upgrade david la porta G-Class 2 09-17-2001 08:07 AM
