» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Coupe/Convertible Forums > W209 CLK Class
Old 04-29-2008, 03:02 AM   #1 (permalink)
Date registered: Apr 2008
Vehicle: Mercedes CLK 320
Electrical quirks - CLK 320
I have just taken ownership of a 2004 CLK 320.
Absolutely love it.
It has a few electrical quirks which I will get looked at the next service in 7000klms time.
Just interested to see if these are common issues.
The problems are..
1) Headrest on drivers side - doesn't always retract when seat is tilted.
2) Same headrest - on occassions refuses to go up or down using door switch
3) I think the mirror(s?) are supposed to dip down on reverse. My passenger mirror (Right hand drive as I am live in sunny Australia - so left hand mirror) - seems to move upwards and drivers side does not move at all. Can someone confirm what the mirror(s) are supposed to do please?
Thanks
dcharle6@bigpond.net.au is offline   Reply With Quote
Old 04-29-2008, 05:52 AM   #2 (permalink)
Date registered: Nov 2007
Vehicle: CLK320 Cabriolet 2004 (A209) in Obsidian Black with two tone grey leather.
Congrats on your new motor. I've got the same model, and I'm delighted too....
Regarding mirrors - the passenger side only tilts when reverse is engaged - but only if that side's mirror button is in on the dash. If the right hand adjuster button is then pressed the mirror returns to its normal position. We're the same as you (I'm UK) so it's the left hand mirror that dips so you can see the kerb (and not scrape that lovely alloy). Driver's side doesn't tilt and this is how MB designed it.
My headrests too didn't always work when I got the car, but six months later they seem okay and work every time - I assume the previous owner had no kids / friends, whereas I've a car full (of kids) every time I get a chance to go for a spin. I think things like electric seats/windows/etc need to be used regularly otherwise they are likely to stick or stop working due to lack of use.
Doug
DougCLK320 is offline   Reply With Quote
Old 05-02-2008, 10:47 AM   #3 (permalink)
Date registered: Oct 2007
Vehicle: 2005 CLK 240 cabriolet
Thanks Doug !!! - I just couldn't figure out why my passenger mirror wouldn't tilt after I programmed it :-)
MikeV
mv51clk is offline   Reply With Quote
Old 05-02-2008, 03:36 PM   #4 (permalink)
Thanks
My mirror seems to move upwards - not down towards the road as would be expected - any ideas how I can reset it to behave as it should?
Old 05-03-2008, 06:10 PM   #5 (permalink)
My mistake - just found out in the hand book I can reset the settings for the mirror in reverse mode.
Still leaves problem with the drivers headrest not retracting - getting the bugs ironed out gradually
Old 05-03-2008, 09:47 PM   #6 (permalink)
unitfreebie's Avatar
Vehicle: 2006 CLK 350
Post
The headrest doorswitch should work regardless if the seat is tilt or not... Try this test: With the seat back and locked, switch the head rest switch up and down rapidly about 100 times... if you see the head rest work just briefly then you have a BAD headrest switch.
If the head rest does not move at all, the switch could still be BAD and not intermittent. Changing the switch is cheaper than changing the motor!
: MBZ 280E, 260E, 300SD
MBZ 190E, E320W, CLK350
unitfreebie is offline   Reply With Quote
Old 05-10-2008, 09:56 AM   #7 (permalink)
Date registered: May 2008
[quote=dcharle6@bigpond.net.au;2869601]My mistake - just found out in the hand book I can reset the settings for the mirror in reverse mode.QUOTE]
I too have the problem of the reversing mirror function going to some compeltely useless position, I can read you can change it, but how exactly do you do that. Do you simply adjust it while in reverse with the controls? Will it remember next time you go in to Reverse where you want it? Do you have to store it in a memory? I tried that but seemed to loose my normal forward driving memory position, I adjusted it when in reverse, stored it while still in reverse, then when I went back to Drive, it stayed in the reversing position.
Gave up trying to get this working properly
Guy
guygamps is offline   Reply With Quote
electrical schematic of mercedes-benz ML 320 CDI virua800 W163 M-Class 1 04-07-2008 02:24 AM
Cultural quirks - driving Corkscrew General Mercedes-Benz 32 05-28-2006 09:31 PM
w124s share of little quirks snik W124 E,CE,D,TD Class 30 01-26-2005 04:01 PM
Will an slk 320 eisenmann exhuast work on my clk 320? Same year too. bib W208 CLK Class 0 12-13-2001 08:51 AM
slk230k quirks jotham R170 SLK Class 30 03-28-2001 02:01 PM
