» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Coupe/Convertible Forums > W209 CLK Class
Old 02-20-2004, 09:17 AM   #1 (permalink)
Date registered: Feb 2004
Send a message via Yahoo to lkirchner
CLK 500 Shift nob replacement
[?]I just took delivery on a 2004 CLK 500. I love the interior but the shift nob looks tacky with the black plastic insert. Has any one replaced their's? If so, how do you remove the original nob? I replaced the nob on my CLK 430 but this appears to be different.
Thanks in advance for your help.
lkirchner is offline   Reply With Quote
Old 04-14-2004, 05:24 PM   #2 (permalink)
Kaiju's Avatar
Date registered: Apr 2004
Vehicle: CLK 240
Send a message via MSN to Kaiju
RE: CLK 500 Shift nob replacement
lkirchner - 2/20/2004 12:17 PM
Hi,
This site may give you a clue even though its for W203 but I believe it's very similar.
http://www.mercedestechstore.com/w203.htm
Cheers,
Ho
CLK240 Avantgarde
--- installed ---
Comand from MBenzNL
OEM Alloy Pedals
-- coming soon --
Siemans S55 phonekit
17" AMG Style 3
http://www.benzworld.org/gallery/showlink.asp?CatID=12191&parentID=51&subname=Kaiju `s_CLK_240&parentname=W209_CLK_Class
Kaiju is offline   Reply With Quote
Old 04-15-2004, 09:00 AM   #3 (permalink)
Thanks, I was able to replace it. It was simple enough to do, much more simple than the C class, and required only a little patience.
Old 04-16-2004, 08:04 AM   #4 (permalink)
DTMCLK's Avatar
Vehicle: 04 w209 Obs Bla Nano
Hi kirchner
Which Gear knob did you change to? and do you have any instructions? or photos of your new knob?
Cheers
DTMCLK is offline   Reply With Quote
Old 04-16-2004, 12:36 PM   #5 (permalink)
I changed to the Schaetz Avantgarde chrome and burl nob. It really dresses up the interior by replacing the leather and black plastic nob. You first have to remove the shift boot by applying pressure to the chrome band at the base of the boot. I found it easiest to push from the side that is straight (versus the curved side) toward the shift lever. Once one side is out the other pops off easily. You then take the leather boot up over the nob. At the base of the nob you will see a black plastic,cone shaped piece the locks the nob in place. Turn this counter clockwise and it will un-lock and then pull it down-ward on the shaft. You can the pull the nob and boot off of the shaft. This may require a little effort but it will come off. At the base of the nob inside the boot you will see a round black plastic nut that holds the boot on to the nob. Unsrcrew this and the boot will come off of the nob. On the new nob there is a replacement cone that secures the nob and boot to the shaft, put this on the shaft. On the new nob there is a metal nut that attaches the boot and nob together. Place the boot on the nob with same orientation that the original one was and tighten the boot and nob togrther. You should use the indent on the leather on the boot that was made by the original nob and black plastic nut as a guide as to how much of the boot should be caught by the new nut. Once this is complete put the nob on the shaft secure it with the cone shaped holder and replace the boot and it's base on the console.
You should be careful to mark the direction of the nob on the boot when it is inside out on the boot to make sure that you are installing the new nob correctly. I installed min backwards the first time. Noproblem but it is always better to do it right the first time.
Old 04-20-2009, 08:50 AM   #6 (permalink)
Date registered: Mar 2009
Vehicle: 2005 CLK500 Cabrio
Show us a picture please! :-D
dmxplicit1 is offline   Reply With Quote
Old 04-20-2009, 08:51 AM   #7 (permalink)
I just had my dealer order two different Schaetz knobs. Going to see them today, but very curious as to how they look installed. Help us out!
Old 04-23-2009, 01:19 PM   #8 (permalink)
Date registered: Aug 2006
Is this it? Click on w209 and scroll just over half way down.
Does it have the benz star on the top?
Schätz - Car Accessories for your Mercedes
CakeDaddy is offline   Reply With Quote
Old 04-24-2009, 06:42 AM   #9 (permalink)
Date registered: Jan 2009
Vehicle: '09 CLK550
Does anyone know if they make any replacement knobs that work with keyless go?
drusus is offline   Reply With Quote
