Old 12-04-2001, 04:54 PM   #1 (permalink)
dman
Posts: n/a
adding an amp and sub (more)
i want to add an amp and sub in my trunk....i was curious to see how the speed senstive volume control of the bose system would work for a separate sub? would the volume of the sub go up and down on the subwoofer as well, or is it impossible to add an amp and sub to the existing bose system? Thanks
Old 12-05-2001, 08:35 AM   #2 (permalink)
Frank
Posts: n/a
The only way to add one is to tap the output of the stock sub...
and adding a high-low converter. Adding it to the existing amp will therefore adapt to the ouput so the speed sensitive volume control will work.
