Vibration at idle whether in drive or neutral, CLK320 - Page 2 - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Coupe/Convertible Forums > W208 CLK Class
Old 02-13-2013, 07:58 AM   #11 (permalink)
Date registered: Jun 2010
Vehicle: W208 CLK320 Cabriolet (2001), W210 E240 (1999)
Originally Posted by liftmys10 View Post
Well I cleaned the MAF but no luck. I also changed out the motor oil today.
I forgot to mention in my first post that the vibration is more noticeable when the engine has fully warmed up.
May I ask have you fixed the problem of engine vibration when idling? I am experiencing similar problem with my clk320.
raymond leung is offline   Reply With Quote
Old 02-13-2013, 09:21 PM   #12 (permalink)
Date registered: Sep 2011
Vehicle: 1998 clk320
Send a message via Skype™ to guku0701
wow i have the exact same issues.i have also changed the motor mounts which i got from napa.after installation its alot better than it used to be but its still not perfect.please share what you found out
thanks
guku0701 is offline   Reply With Quote
Old 02-14-2013, 06:58 PM   #13 (permalink)
Date registered: Jul 2009
Vehicle: 2001 CLK 320
thanks
I replaced my transmission mount again about 1 month ago with an OEM. Believe it or not, it helped out alot compared to the cheaper aftermarket transmission mount i had put on in 2009. I only did the transmission mount since it is very easy to do. I highly recommend doing that alone before the other engine mounts and buy it from the dealer or a genuine OEM. Seems like the aftermarket rubber bushings are not that good.
2001 CLK 320
liftmys10 is offline   Reply With Quote
Old 02-17-2013, 04:33 PM   #14 (permalink)
Thanks for replying. I will first replace the transmission mount and if that does not help enough I will also replace the engine mounts. Will definitely share the outcome! Thanks again.
Bookmarks
