defective lamp warning - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 04-15-2012, 01:08 AM Thread Starter
Date registered: May 2010
Vehicle: clk 320 2000 model
keep getting the message defective light warning but have checked all lamps ok
scuppy is offline
post #2 of 4 (permalink) Old 04-15-2012, 03:10 PM
28-psi's Avatar
Date registered: Nov 2007
Vehicle: 2002 CLK55 AMG
This topic has been beat to death and the culprit is usually one of the license plate bulbs...typically overlooked
28-psi is offline
post #3 of 4 (permalink) Old 04-16-2012, 04:41 AM Thread Starter
no all globes are working including number plate globes
scuppy is offline
post #4 of 4 (permalink) Old 04-16-2012, 09:27 AM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 247 Post(s)
I had the same experience about 3 years back. On the W209 the cluster message identifies the failed lamp - except that it was working fine.
Some weeks later, one licence plate bulb did fail to operate, but on inspection the bulb was OK and just cleaning the contacts fixed the problem.
So I expect that all your bulbs are OK on the full working voltage, but one of them throws a false fail when tested by the lower diagnostic voltage. Not much you can do, unless you want to clean up the contacts of all the exterior lights...
You could just try cleaning the licence plate bulbs contacts, and that might fix it. That area get more exposure to the weather than the other lamps.
keyhole is offline
  Mercedes-Benz Forum > Mercedes-Benz Coupe/Convertible Forums > W208 CLK Class
User Tag List
display defective ,abs,bas,lamp defective murraycowan W210 E-Class 19 02-14-2012 01:10 PM
Code reset needed after Defective Lamp warning Musikmann W210 E-Class 8 10-13-2009 10:54 AM
E430 lamp defective message - vanity mirror lamp out mgia0007 W210 E-Class 7 01-04-2009 01:11 PM
defective lamp warning solarant W210 E-Class 9 11-19-2007 12:13 PM
Lamp Defective Warning turns off cluster and climate lights davebrewer W210 E-Class 1 10-30-2007 05:35 PM
