replacing license plate bulb - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 05-10-2011, 03:10 AM Thread Starter
davidclk's Avatar
Date registered: Nov 2008
Vehicle: Mercedes CLK 230 kompressor
One of my license plate bulb is shot so i wanted to replace it...so i have to remove the plastic cover that holds the two bulbs...
the problem is that i easily remove the 2 exterior screws that hold it but in the middle there is a RIVET...i tried GENTLY to find a way of removing it but with no chance...
do u guys have a rivet in the middle too...and if so how do u remove it?
i know this is dumb but i don't want to scratch anything if there is a easier way.
tks
K&N filter
BREMBO brake disks
Free Flow exhaust
Radiator Panel
davidclk is offline
post #2 of 10 (permalink) Old 05-10-2011, 06:56 AM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 197 Post(s)
Something wrong here. Maybe a previous owner did this, if he broke the clips getting it off.
According to the WIS, this lamp change is very straightforward.
1. Unscrew 2 screws and remove the handle from the trunk lid.
2. Unclip licence plate. Use a thin plastic wedge to unclip the licence plate from the trunk lid.
keyhole is online now
post #3 of 10 (permalink) Old 05-10-2011, 10:36 AM Thread Starter
davidclk's Avatar
i atached this image to give u a hint...
the 2 screws and in the middle the rivet..i mean i cannot at least grab it with a pair of something,clippers or..., to turn it the other way around to see if it unscrews cause the space doesn't allow u to...
i'm buggered cause whether the previous owner was a knuckle head or was it suppose to be like this and mabe from the inside of the trunk i have to take out something in order to remove that rivet...hmmmm
tomorrow i'm going to make a picture and let u see what i'm talking about...mabe u have a pic of yours letting me see if u have a rivet in the middle cause
K&N filter
BREMBO brake disks
Free Flow exhaust
Radiator Panel
davidclk is offline
post #4 of 10 (permalink) Old 05-10-2011, 05:03 PM
keyhole's Avatar
Quoted: 197 Post(s)
No. My ride is a W209, so this panel is different on mine.
post #5 of 10 (permalink) Old 05-11-2011, 10:26 AM
Date registered: Sep 2008
Vehicle: clk 320
David i think you actually have to remove the headliner in the trunk to remove that rivet.
expressbenz is offline
post #6 of 10 (permalink) Old 05-11-2011, 01:09 PM
A1EK's Avatar
Date registered: Sep 2005
Vehicle: W208 CLK230K 2000 year, Past -W203 C Class, W202 C Class, W210 E Class, W201 190E
Quoted: 4 Post(s)
Guys Guys! Stop! I am always surprised at the amount of times I read people trying to remove the plastic lenses to replace the bulbs, you DONT need to.
You work from the inside of the car not outside, Remove the two plastic push pins and just pull the lining down inside, you will then have access to the rear of the lights.
Why not replace with some nice White LED's!
Enjoy....
ID:	374673   Click image for larger version
ID:	374674   Click image for larger version
18x235x40 (8.5J) & 18x255x35 (9.5J) Brabus Monoblocks VI reps, Eibach Pro lowering kit, no#1 pad front & rear, Rolled arches,20mm rear spacers/15mm front, Flat emblem, Kompressor skirt badges, Parking sensors, Colour coded grill, Front flat lip, Front eccentric camber bolts, Denso Irridium plugs, K&N filter, Sony ICE adapted to steering wheel buttons, Blue LED modified dash & interior.
][/B]
A1EK is offline
post #7 of 10 (permalink) Old 05-12-2011, 03:04 AM
keyhole's Avatar
Quoted: 197 Post(s)
It seems the WIS has given me bad information here (post #2) or maybe that drawing was OK for the early W208s.
It stated it was for W208 and W210 models.
post #8 of 10 (permalink) Old 05-12-2011, 05:35 AM Thread Starter
davidclk's Avatar
Thank u A1EK ... i guess it was the other way around,as i was thinking too just wasn't sure of it...today i took the pic to show u but it seems i don't have to...anyway i'll post it and soon i'll change that little bulb cause its annoying everytime i turn on the lights to have the "1 malfunction" warning.
Keyhole...when u said about only 2 screws i was kinda blocked thinking "how come i have 3"
Thanks for the info everyone...i guess sometimes the little ones give u the nightmare
K&N filter
BREMBO brake disks
Free Flow exhaust
Radiator Panel
davidclk is offline
post #9 of 10 (permalink) Old 02-03-2012, 03:37 AM
Vehicle: 2011 C200 CDI
Hi guys. Had to replace the numberplate bulb on my CLK cabriolet today and this thread was very helpful. Thanks.
I had looked initially at WIS and to give them credit, they do call the procedure "Replacing license plate LAMP", not "Replacing license plate BULB", so I guess they're technically correct. However, I too have the "rivet" in the centre. Having removed the trunk lid lining to get to the bulb, I could see that this "rivet" is in fact a smooth headed bolt, as it has a small nut on the back! I guess the shaft must be square or have a flat side, otherwise the bolt would turn when you tried to unscrew the nut. So despite what WIS says, you'd have to remove the trunk lid lining even if you wanted to replace the LAMP rather than just the bulb.
On the cabriolet, removing the lid lining was a bit tricky, as there is a "plunger" for pushing the trunk lid open and it passes through a plastic "collar", clipped into the trunk lid. This collar firmly holds the lining in place. I tried levering it out with a screwdriver and ended up chipping off a chunk of the flat flange :-(. In the end, I found I could leave the collar in place, and gently lever the lining from around the collar using a largish screwdriver. This may help other cabriolet owners who encounter the same problem.
Thanks for all the help.
2011 C200 CDI 12500kms
RobCox is offline
post #10 of 10 (permalink) Old 09-19-2012, 07:42 AM
Date registered: Jul 2012
Vehicle: 2001 CLK 430
AEK - your post was slamming!! It worked perfectly. I was trying to get at those lights from the outside screws. It was never going to happen.
DavidCLK- thanks for the photos. I have the same set-up on 2001 CLK 430.
I also have the "plunger" and was able to leave it and just turn move the liner from side to side to get to the lights.
Thanks for your posts.
birkie23 is offline
  Mercedes-Benz Forum > Mercedes-Benz Coupe/Convertible Forums > W208 CLK Class
User Tag List
Replacing light bulb for license plate bjorkson W208 CLK Class 8 11-28-2012 06:40 PM
License plate bulb holder? metidogeno W164 M-Class 1 03-02-2009 11:27 PM
License Plate Bulb Replacement oh_boy W210 E-Class 5 12-16-2006 10:25 PM
changing license plate bulb michaeljacob W210 E-Class 2 11-03-2004 01:34 PM
How do I replace the license plate bulb?... Dany (Toronto) R170 SLK Class 3 12-12-2001 05:27 PM
