Replaced Brake Light Switch; BAS/ASR still on - Page 2 - Mercedes-Benz Forum
#11 (permalink) Old 05-12-2011, 02:06 PM
Date registered: Nov 2006
Vehicle: 99 CLK 320
OK, fine.
Went to the MB dealer and bought the overpriced BLS. Guess what? BAS/ASR light still on.
They tell me it might be a wheel speed sensor, but they want a picture of Uncle Benjamin to make it happen.
That may explain the weird mileage I'm recording when I fill up. I have a SCANGUAGE-II hooked up to my OBD-II port and the miles recorded is a few off compared to the odometer.
I see there are FOUR of these wheel speed sensor (one each wheel)...wow! That's about $400. Do you guys just replace the (hopefully) one or do all four "while you're at it and have the car up?
Also, the cruise control seems to work PART of the time. It did not work at all last Sunday. Yesterday it was working.
What I've done so far:
-Replaced BLS
-Disconnected the battery 60 minutes; manual reset ECU
-Checked continuity of all fuses (firewall driver side; driver door; trunk; k-40 area)
-Steering wheel lock right, left center
Still have the BAS/ASR light on.
Last edited by semiretired; 05-13-2011 at 01:11 PM. Reason: cruise control info added; what I've done so far
semiretired is offline
  Mercedes-Benz Forum > Mercedes-Benz Coupe/Convertible Forums > W208 CLK Class
If you do not want to register, fill this field only and the name will be used as user name for your post.
User Tag List
2002 C320 ESP/BAS warning, but never had Stop Lamp Switch / Brake Light Switch. ant68 W203 C-Class 4 01-10-2015 07:05 AM
BAS/ASR Light - Brake Light Switch - Are There Any Physical Signs of Malfunction? FAR888 W202 C-Class 9 05-10-2011 07:48 AM
BAS light - replace brake switch first? jjjjgong W163 M-Class 2 02-16-2011 08:30 AM
please help! ASR/BAS & 3rd brake light youngblood W210 E-Class 3 07-30-2009 10:16 AM
BAS ASR Light on, brake switch changed, codes cleared daoudh R170 SLK Class 1 11-11-2008 07:25 PM
