Sunroof fuse - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 03-06-2011, 03:37 PM Thread Starter
Mslaughter's Avatar
Date registered: Feb 2011
Vehicle: Brilliant Silver CLK 320
Sunroof fuse
My sunroof is on the fritz. A few days ago, I tilted the rear up on my way home but couldn't get it to come back down to the closed position. I checked the manual and was able to close it with the tool. Today, I left my girlfriend in the car and she tried to open it, and again, it would not shut. This time though, the tool was left in my garage and we were nearly caught in the rain. I'm not due for service for another 4k miles; could I pull the sunroof fuse to prevent anyone from messing with it until I get it in for service or will other accessories be affected?
Mslaughter is offline
post #2 of 10 (permalink) Old 03-07-2011, 03:00 AM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 170 Post(s)
Sunroofs do need the occasional cleanup and lubrication.
There are 4 versions of W208 fusebox layouts/details, with minor differences.
1. Coupe up to 31/5/1998
2. Coupe 1/6/1998 to 31/5/1999
3. Coupe as of 1/6/1999
4. Cabriolet
One of the reasons that members are asked to fill in a profile of their ride/location with UserCP ^^^ is that it often helps with answers. In your case, as you have not provided any details of the year of manufacture of your CLK 320, it is not possible to be certain with fuse details. However, for the sunroof fuse f9 there are just a few changes in the models. The fuse protects the OCP (overhead control panel) items, as follows:
1) sliding/pop-up roof. 2) front/rear dome lamps. 3) rain sensor. 4) convenience closing. 5) make-up mirror. 6) inside rearview mirror dimmer. 7) interior R/F receiver. (C/L) 8) outside rearview mirror dimmer. 9) switch illumination. 10) garage door opener.
Some of these are options that you might not have.
keyhole is offline
post #3 of 10 (permalink) Old 03-11-2011, 02:38 PM Thread Starter
Mslaughter's Avatar
Thanks for the response Keyhole, it's a '99. Today, I pulled the fuse and re-synced it and now it opens and closes in 1 motion. After it gets about 2/3 open though, it starts slowing down, like there's some hesitation or resistance. I found the DIY and lubed the guides and everything, even though there was still some there, but that didn't fix it. If I let it open all the way it slows down towards the end and then it's very tough to start moving again to close, but after that 1/3 mark it speeds up and closes like normal? There are no obstructions in it's path that I can see, any ideas?
post #4 of 10 (permalink) Old 03-12-2011, 04:27 AM
keyhole's Avatar
Quoted: 170 Post(s)
Not really...
What happens if you give the motor a little 'gentle assistance' by pressing on the roof while it is moving? If that overcomes the slowing down, there has to be some physical resistance to the roof movement somewhere. The motor is only stopped when the memory calculates that it is at the end of its travel, when it has been reset (normalized).
keyhole is offline
post #5 of 10 (permalink) Old 03-22-2011, 06:25 PM
Date registered: Mar 2011
Vehicle: 2004 e320 4matic
I've got a 04 e320. Same problem. Can't find fuse! Pulled all fuses on side box and still moved! Grrrrrrrr
Vanstee is offline
post #6 of 10 (permalink) Old 03-25-2011, 03:36 PM
keyhole's Avatar
Quoted: 170 Post(s)
We are dealing with W208 CLK here...
Your W211 has f1 to f 20 in the trunk. Find f9 in fuse & relay box N10/2.
keyhole is offline
post #7 of 10 (permalink) Old 03-25-2011, 09:55 PM
Vehicle: A Faster car than Yours
your sunroofs are begging to be cleaned and lubed and resynced at the dealer. for god sakes just have it done before you burn out your 400 dollar motor or destroy the teeth of the cables of your 1500 dollar sunroof frame. it prob wont cost you 75 bucks.
dealermastermechanic is offline
post #8 of 10 (permalink) Old 03-26-2011, 01:42 PM
keyhole's Avatar
Quoted: 170 Post(s)
This was stated in post #2
But why the dealer..? Do you think that we are not smart enough to DIY a simple task like this?
keyhole is offline
post #9 of 10 (permalink) Old 03-26-2011, 03:06 PM
amschnellsten's Avatar
Vehicle: 2001 clk55 AMG
you can do it yourself. I think a Dealer wrote the previous statement. Take it to an Indy if you can not figure it out.
amschnellsten is offline
post #10 of 10 (permalink) Old 03-28-2011, 03:25 PM
Thanks for the info. Resynced and works like a champ
Vanstee is offline
  Mercedes-Benz Forum > Mercedes-Benz Coupe/Convertible Forums > W208 CLK Class
User Tag List
2000 ML 320 Lighter Fuse Blown | Which fuse do I replace? Patkar g_patkar W163 M-Class 11 01-20-2015 05:34 AM
Window wont roll up, Diagram of fuse box, which fuse is for the power windows? gpacheco101 R/C107 SL/SLC Class 8 03-09-2010 07:49 AM
Sunroof failed.... fuse? Cyberbach W123 E,CE,D,CD,TD,TE Class 3 09-18-2009 06:51 PM
Sunroof blew a fuse and now windows don't work GDC W124 E,CE,D,TD Class 3 06-18-2007 08:42 AM
1994 463 Which Fuse for Power Sunroof? mserpe G-Class 4 09-09-2005 04:41 PM
