» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Coupe/Convertible Forums > W208 CLK Class
Old 11-16-2009, 02:24 PM   #1 (permalink)
Babalu95's Avatar
Date registered: Mar 2009
Vehicle: 2001 CLK 320
My tranny downshifts while on level highway. Normal driving.
Why does it do that? I'm driving at 60mph @2000 RPM or so, then all of a sudden it downshifts and my RPM's are at about 2500. As if uphill driving. However, I'm on a a level highway. It will not shift back to 5th gear till i start over again. Any suggestions?
Babalu95 is offline   Reply With Quote
Old 11-16-2009, 02:37 PM   #2 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
How many miles?
Have you serviced the transmission?
Is the fluid level correct?
Is the connector leaking?
Have you reset the shift points to defaults?
If we ever forget that we are one nation under God, then we will be a nation gone under.
Ronald Reagan
Old 11-16-2009, 05:51 PM   #3 (permalink)
Babalu95's Avatar
My tranny...
My car has about 80k miles. I myself have never had the tranny serviced. I was thinking of changing the tranny filter/fluid this weekend. I don't know what else to do. I could go the dealer and throw myself at their feet to have pitty on my wallet. How does one check the fluid by the way?
Old 11-16-2009, 08:03 PM   #4 (permalink)
ZYALATR's Avatar
Date registered: Jan 2007
Vehicle: 1999 CLK 430 ,Silver/Ash, Daily Driver
Send a message via AIM to ZYALATR
Question # 1 CLK55/430/32..????
Tranny service is worth it from an authorized Benz mechanic. I had my 99 430 done at the dealer and it was about $300.. Well worth it. The tranny was drained and the torque converter was drained also. There is a procedure on our cars that is important.
The BS tranny flushes that the "Midas" style shops are just that. BS... You can also reset the tranny . There are some threads on this depending on your car in here. Enjoy the ride !
ZYALATR is offline   Reply With Quote
Old 11-16-2009, 10:10 PM   #5 (permalink)
gregs210's Avatar
Babalu, if you have it done they can reset the shift pattern for you. If you DIY you have to buy MB fluid ($15/Lt) which is why it's roughly a $300 job at the shop. You also haveto buy a dipstick tool.
I'd check the connector first to see if it's been leaking, that can contaminate the TCM.
Check the 210 forum stickies for the DIY info and the 722.6 FAQ info, that will get you started down the right path.
Old 11-17-2009, 02:42 PM   #6 (permalink)
click430's Avatar
Date registered: Aug 2005
Vehicle: 01 CLK 430, '05 Z4
YEP... I had my tranny serviced at an MB dealer... Well worth it.. while the filter was off, he found the connector WAS leaking... (a $12 part) Saved the rest of the electronics. Shifts are smooth again.
click430 is offline   Reply With Quote
Old 11-19-2009, 10:00 AM   #7 (permalink)
Babalu95's Avatar
Taking it to the shop soon...
How does one check the fluid level anyway?
Old 11-23-2009, 07:25 PM   #8 (permalink)
oreif's Avatar
Date registered: Sep 2008
Vehicle: '00 w163 55 amg '02 w208 55 amg
Send a message via MSN to oreif
these chassis are back in the 'sealed-for-ever' days. onboard computer will let you guage oil but I don't think you can 'check' the tranny oil honestly without a dipstick.
hope i am incorrect for your benefit
oreif is offline   Reply With Quote
ML320 02 engine oil level going down when i drive it in long highway ismaelmansieh W163 M-Class 6 05-26-2009 10:47 AM
Stalled after highway driving briandale R/C107 SL/SLC Class 7 05-30-2006 08:02 PM
Normal Loudness on the Highway? OneMnk W123 E,CE,D,CD,TD,TE Class 10 01-13-2005 11:33 PM
Highway driving Poulsbo Paul G-Class 4 06-04-2002 06:15 PM
Without mudflaps, will paint be damaged with normal city and highway driving? Thanks DT W163 M-Class 15 01-07-2002 10:44 PM
