» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Coupe/Convertible Forums > W208 CLK Class
Old 11-02-2009, 03:48 PM   #1 (permalink)
Date registered: Feb 2009
Valve Cover Torque Spec
Hey,
I am replacing the valve cover gaskets due to a leak. I need the torque spec for the valve covers. Anybody?
2000 CLK430.
Thanks.
Clicquot is offline   Reply With Quote
Old 11-02-2009, 04:08 PM   #2 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
The valve cover or breather cover? The latter have no gaskets and commonly leak by 75K or so (and need to be resealed), the former rarely leak.
IIRC the VC bolts are not very tight at all, just 8 or 10 NM. The little breather cover bolts are like nut-driver tight, like a screw. If you search in the 210 forum you'll find it, loubapache posted it.
If we ever forget that we are one nation under God, then we will be a nation gone under.
Ronald Reagan
Old 11-03-2009, 07:23 AM   #3 (permalink)
Thanks gregs210. I appreciate yuor response.
2001 E320 Valve Cover Torque DClary W210 E-Class 7 09-03-2009 10:17 PM
Valve Cover Torque Specs sswong98 W163 M-Class 15 08-27-2009 08:00 AM
Valve Cover Torque mercedesbenz911 W123 E,CE,D,CD,TD,TE Class 13 07-22-2009 11:02 AM
Valve Cover Torque Skogs W123 E,CE,D,CD,TD,TE Class 3 03-27-2006 07:10 AM
Valve cover torque spec? page62 R/C107 SL/SLC Class 2 01-18-2006 04:05 PM
