Windscreen washer tank leaking - Mercedes-Benz Forum
post #1 of 14 (permalink) Old 09-20-2009, 07:20 PM Thread Starter
Max Korin's Avatar
Date registered: Dec 2008
Vehicle: CLK500, 2003 W209, Brabus Alloys, Quad Exhausts, Lowered H&R springs. All the bells & whistles...
Question Windscreen washer tank leaking
Hi Guys, (includes Gals too )
Just done a forum search with no useful results.
My screen wash tank keeps losing 80% of its contents to the point
where the warning message appears on the dash.
Has anyone had experience of removing the tank ?
At first glance - some of the pipework seems pretty rigid and I'm
not sure how I'm going to get it off to inspect it.
Is there anything I should be looking for ??
Either as I remove it or generally to identify the leak.
Are specific seals known to be weak ?
I may need to invest in a workshop CD rom.
Any pearls of wisdom welcome !
Max Korin is offline
post #2 of 14 (permalink) Old 09-21-2009, 09:28 PM
Date registered: Mar 2009
Vehicle: CLK430
mine was always leaking until i removed and plugged up the headlight washer tube.
mine was always draining somewhere down by the headlight washers.
i never used those anyway.
the tube was accesable without removing the tank, just traced it a bit to make sure it was the right tube, i think i cut it and plugged it with a bolt and a zip tie.
wedged it so the tube was higher than the level of the bottle , just for extra safety.
lextoy35 is offline
post #3 of 14 (permalink) Old 09-21-2009, 09:41 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 15 Post(s)
A fairly common leak point is the washer pump grommet, it's a cheap (and inexpensive) part that takes five minutes to change.
Check Codes is offline
post #4 of 14 (permalink) Old 09-23-2009, 08:31 AM
jstetor53's Avatar
Date registered: Sep 2007
Vehicle: 2000 320Clk Cabrio
I second this one....just fixed mine last week. there is an "o" ring on the washer pump that needed replaced. 10 min job. I've already replace the headlight squirters but that is worth a look too as mentiuoned above.
jstetor53 is offline
post #5 of 14 (permalink) Old 09-23-2009, 11:55 AM Thread Starter
Max Korin's Avatar
Thanks Guys,
Greg - is there a sticky or DIY thread you know of ?
I've done a search but no luck so far
jstetor53 - was it obvious as to the procedure ?
Did you have any manual to follow ?
I don't want to take your time but could you summarize your "10 min job" sequence
Thanks again guys
Max
post #6 of 14 (permalink) Old 09-23-2009, 12:05 PM Thread Starter
Max Korin's Avatar
Update
Sorry Greg - just done a more specific search for "washer pump grommet"
and got plenty of threads to read through.
So my question has changed...
I know the W210 E class share engine bays with the W208 CLK, but are there any other models with similar engine bays where the washer pump set-up may be the same. I can't see a W208 in the search results.
Thanks
Max
post #7 of 14 (permalink) Old 09-23-2009, 03:15 PM
jstetor53's Avatar
Originally Posted by Max Korin View Post
Thanks Guys,
Thanks again guys
Max
k I don't have a camera here at work but let me see if I can explain my leak, it is very easy . If you look at the front corner of your washer bottle (inboard coroner) you will see the pump, its a vertical cylinder with a wire plug on top. At the bottom of the pump you will see a braided hose leading out of the pump, there is a black clip that just slides on and off to hold the braided hose into the pump. pull the black clip and the hose and connector will pull out of the pump. you will see an "o" ring on the connector that is probably shot , mine was. Hope this helps
post #8 of 14 (permalink) Old 09-24-2009, 10:30 AM Thread Starter
Max Korin's Avatar
Thumbs up Sounds so easy....
Thanks Jstetor53, I'll take a look at it again with that in-mind
It does sound easy....
(famous last words !!)
post #9 of 14 (permalink) Old 09-25-2009, 06:39 AM
jstetor53's Avatar
LOL i hear ya on the famous last words but this one truly is a 10 min job....I used a small scre drive to pry the black clip off Good luck
post #10 of 14 (permalink) Old 04-18-2010, 03:56 PM Thread Starter
Max Korin's Avatar
Smile EASY pdf guide to screen washer motor repacement
Well I finally got the job done...
I'd been putting it off for ages but the screen washer motor died so I had no choice !!
It was easy - and to prove it, for anyone else who needs to replace either the washer motor or the rubber grommet between the motor and the plastic tank here is an EASY step by step guide with photos.
Hope that helps
Regards
Max
  Mercedes-Benz Forum > Mercedes-Benz Coupe/Convertible Forums > W208 CLK Class
User Tag List
Windscreen Washer nozzle(s) Haku W140 S-Class 3 05-02-2008 07:49 PM
Windscreen Washer Not working denverbres W210 E-Class 4 02-16-2008 03:05 PM
Leaking washer fluid tank caused $2,700 damage geebrewger W163 M-Class 11 04-23-2007 10:19 PM
Windscreen washer problems cmowen R170 SLK Class 2 01-19-2005 12:57 PM
Windshield Washer Fluid Tank Leaking Guest (MBNZ) W203 C-Class 2 10-06-2002 06:49 AM
