serpentine belt DIY missing - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 08-12-2009, 09:50 PM Thread Starter
Date registered: Feb 2008
Vehicle: 2004 (w220) S500 & 2001 CLK320 Cabriolet V6 3.2 L
Eventually everybody on this forum will need this procedure.
Can anyone give a good posting with tools needed and possibly parts?
Since I know I will have to do it close to 90,000 relatively trouble free miles I am carring around a spare belt, tensioner assembly and idler pulley just so as not to get stranded. I just wish I knew what tools I need as I can't lug all of them around. Some tips about the procedure would be great too.
Thanks
poptopclk is offline
post #2 of 11 (permalink) Old 08-17-2009, 03:09 PM
Date registered: Jul 2008
Vehicle: 2000 CLK 320 1999 ML 320 2010 E350
Having mine replaced tomorrow I will let you know if anything comes up that you need to know.
bjwarren is offline
post #3 of 11 (permalink) Old 08-18-2009, 05:27 AM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 228 Post(s)
poptop
I haven't done it myself, but this is the procedure from my WIS. Not too difficult - but not really a roadside job. Just make sure that you have the right size torx wrench to unscrew the stud bolt.
ID:	254847   Click image for larger version
ID:	254848   Click image for larger version
keyhole is offline
post #4 of 11 (permalink) Old 08-19-2009, 06:51 AM
OK so I changed the Pully, Tensioner and the belt. Have to say it was pretty easy. If you pull out the fan it really makes it a dream. The hardest thing was getting the pully bolt out but if you massage the rad the right way your set. The Tensioner I put back on had a nut welded next to the pully so it was really easy to take off the tension and pull the pin. Let me know if you have troubles I may be able to help out.
bjwarren is offline
post #5 of 11 (permalink) Old 08-20-2009, 05:05 AM
keyhole's Avatar
Quoted: 228 Post(s)
Tell me, was it hard to undo that torx bolt? Did you need to use a breaker bar to shift it? What stops the tensioner wheel turning while you try to remove the bolt? How do you get the correct tension back?
keyhole is offline
post #6 of 11 (permalink) Old 08-24-2009, 07:16 AM
The torx bolt was not too bad but I did have to give her a good pull. The wheel spins around the bolt (bolt does not move). The tensioner is spring loaded so once the belt is on your set. Let me know if you need anything more.
bjwarren is offline
post #7 of 11 (permalink) Old 09-05-2009, 01:13 PM
Date registered: May 2009
I have a question
I have CLK55. when i start my car in the morning, i get a belt noise. It stays for like 4 minutes and goes away. Is it the serpentine belt which is making this noise?
Thanks,
Raj
rajramineni is offline
post #8 of 11 (permalink) Old 10-21-2013, 07:49 PM
Date registered: Oct 2013
Quick question. Lost our belt two miles from home today. Noticed the belt was all chewed up on the edges and broken, obviously. The pulley looks bent and there are some small metal flakes around it. How do we know if we need change the entire assembly or just the pulley? Thanks!
Benz Newb is offline
post #9 of 11 (permalink) Old 10-22-2013, 03:43 AM
keyhole's Avatar
Quoted: 228 Post(s)
There are 6 or 7 pulleys altogether. Which one is damaged? If the shaft is bent you may have to replace more than just the pulley.
Btw - these poly-V belts should be examined during a service for signs of fraying, etc.
keyhole is offline
post #10 of 11 (permalink) Old 10-22-2013, 06:14 AM
It is the tensioner pulley.
I am puzzled a bit as well as to how this was missed during service. According to the Mercedes dealership, the car was just taken in for maintenance in late May by the previous owner. Of course it could have just happened, but that belt looks pretty old to me.
  Mercedes-Benz Forum > Mercedes-Benz Coupe/Convertible Forums > W208 CLK Class
User Tag List
"V Belt" as MB calls it or Serpentine Belt 98MBE320 W210 E-Class 12 01-05-2010 02:36 PM
Serpentine Belt Replacement doctor2687 R129 SL Class 15 08-29-2009 07:03 PM
DIY Serpentine belt removal?? CBFintheODD W210 E-Class 8 01-24-2008 05:03 PM
SERPENTINE BELT - what is? lnguyenh R129 SL Class 5 04-25-2005 02:07 PM
Serpentine Belt bdonkersgoed W140 S-Class 7 06-01-2004 06:32 AM
