w208 clk front seat fore/aft motor how to - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Coupe/Convertible Forums > W208 CLK Class
Old 07-18-2009, 06:00 PM   #1 (permalink)
Date registered: Feb 2008
Vehicle: 2004 (w220) S500 & 2001 CLK320 Cabriolet V6 3.2 L
The seat motors start to tell you they are going bad by blowing fuses in the trunk.
When you check the fuses and find they are all OK and the seat makes clicking noises but won't move ,
WELL THEN YOU GOT YOURSELF A DEAD MOTOR!
I came up with a fast way to replace the motor WITHOUT removing the entire seat.
Sometimes your seat will be in a position where you can't get to the bolts to remove it, so this way works
regardless.
Take a T27 wrench as pictured and remove the right front & left front seat bottom bolts from
the seat bottom as pictured. You don't have to remove anything to get to them. You might adjust
the seat lift and rise to get a good angle.
Once both bolts are off then seat lifts up giving good access to the area.
Disconnect the 4 plugs from the front of the metal bracket which holds the plastic black box
which all the wires go to. Remove the small nut on the front right corner and the T25 bolt
on the left side. You can now have farily free access to the fore/aft motor.
IT IS THE CENTER MOTOR which moves fore/aft. Clip all the zip ties on the center motor leading
to the controller so you will be able to unplug it from the bottom.
Use the T25 handled driver from the picture to remove the motor top bolt & then remove the bottom
bolt using the same tool. The motor is now out.
The small shaft remains behind so carefully slide the new motor in place. Put in the top bolt
& then the bottom bolt. Connect your wire into the scoket from which you unplugged
the dead one from.Hint the plug orientation has the colored wires the same as the adjoining plug.
Replace the nut from the silver controller bracket and the T25 bolt and your controller is back in.
Reconnect the 4 plugs running along the front of the silver bracket.
Now replace the two T27 bolts from the left & right seat front edges to the cushion.
That's it about 35 mins.
w208 clk front seat fore/aft motor how to-tools-w-part-number.jpg   w208 clk front seat fore/aft motor how to-right-passenger-seat-front-corner.jpg   w208 clk front seat fore/aft motor how to-2-x-t27-front-seat-screws.jpg
poptopclk is offline   Reply With Quote
Old 07-18-2009, 11:33 PM   #2 (permalink)
Date registered: Jun 2009
Vehicle: 2000 CLK430 Cabriolet
Thank you, poptopclk, for sharing with us your experience.
CKK430 is offline   Reply With Quote
Old 08-01-2009, 01:18 PM   #3 (permalink)
StigHelmer's Avatar
Date registered: May 2004
Vehicle: 2002 CLK320, 1980 300SD Turbo, 1995 C220, Kawasaki Ninja 500R, Yamaha YZF600R
Send a message via AIM to StigHelmer Send a message via Yahoo to StigHelmer Send a message via Skype™ to StigHelmer
You are a good man.
StigHelmer is offline   Reply With Quote
Old 08-01-2009, 02:57 PM   #4 (permalink)
big_mike1979's Avatar
Date registered: Oct 2006
Vehicle: clk320 (2001)
bump good man
VIPclk320 Cold Air Ram Intake
VIPclk320 Front & Rear Strut Bars
K-Mac Front & Rear Camber Kit
H&R Aggressive Spring & NO pads (2.5 inches all around)
Koni Adjustable Shocks
H&R Rear Spacers 15mm
Custom Exhaust
No Resonator
5 Spoke Benz Rims 19 by 8.5 (Dipped in Chrome)
3% Limo Tint
Halo Projector headlight with HID H7 and 30000K royal blue and HID fog light 20000k royal blue and LED side markers.
big_mike1979 is offline   Reply With Quote
Old 08-03-2009, 12:23 PM   #5 (permalink)
joshrio's Avatar
Date registered: Mar 2009
Vehicle: 2001 Mercedes CLK 320, 2000 Dodge 1500
Send a message via AIM to joshrio
this is an excellent method.
I had a plastic cup get wedged under the seat which burnt the motor out, i used this method had the new motor installed in about 20 minutes. Thank you!
joshrio is offline   Reply With Quote
Old 08-03-2009, 12:56 PM   #6 (permalink)
Since this has been verified ... Sticky DIY ?
Thanks for the independent confirmation.
Perhaps the great moderatio will place this in the sticky DIY.
It really is a huge improvement on this repair Vs all the other ways to try it.
Old 08-05-2009, 02:17 PM   #7 (permalink)
joshrio's Avatar
I got my seat motor here:
GENUINE MERCEDES 208 820 08 42 Seat Adjustment Motor Forward / Back (2 Needed Per Car) CLK320 208.365- 208.365 2088200842 - Above All Motorwerks
I ordered it on Monday and it was delivered Wednesday by Fedex.
Old 08-06-2009, 12:51 PM   #8 (permalink)
Same motor New in box OEM Benz part
It is the exact one from my DIY picture posting... the stupid company I ordered from duplicated the order so I now have a brand NEW fore/aft seat motor A208-820-08-42
That I have no use for.
New in Mercedes Box will sell it for my cost 99.00 incl shipping anywhere in the main 48 states. Can do paypal pvt message me
Old 08-17-2009, 12:40 PM   #9 (permalink)
StigHelmer's Avatar
...wait how the hell did you get to the left side (or interior side) bolt - it looks impossible to access on my seat
Old 08-17-2009, 01:55 PM   #10 (permalink)
StigHelmer's Avatar
this is becoming a flipping nightmare.... I got the interior screw up, but the middle motor has a NEEDLESS bolt on the underside of the motor that is basically impossible to get to...
Looking up in WIS if this is even possible on my car (or if I am looking at the right motor.)
GOD I HATE GAY T27 SCREWS
EDIT : Okay I figured it - that took me longer than it should have - thanks poptopclk for the motor!
Bookmarks
fore and aft window adjustment drk1074 General Mercedes-Benz 0 06-02-2009 07:09 AM
Source of fore-aft oscillation damping? ChuangTzu W123 E,CE,D,CD,TD,TE Class 5 03-28-2008 12:05 AM
Anyone know if a fore/aft seat motor from a W210 will work in a W208? jtoma878 W208 CLK Class 0 10-22-2007 11:47 AM
seat fore/aft lever barndogz R170 SLK Class 12 04-12-2005 04:38 PM
Problem with seats fore and aft adjustments BREY W208 CLK Class 0 12-17-2002 09:08 PM
