» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Coupe/Convertible Forums > W208 CLK Class
Old 07-03-2009, 01:44 PM   #1 (permalink)
Date registered: Jan 2008
Vehicle: 2001 clk430 cabrio
Lag when unlocking door
So heres another funky thing going on with my door. Whenever I pus the unlock button on my remote start, the door does not unlock for a couple seconds. Sometimes I need to push the unlock button the remote atleast a good 10 times. Usually after the tenth time that means I need to open up the trunk, unhook the damn battery cable, put the cable back on then everything works again instantly! Anyone think about installing a kill switch attached to the negative side of the battery so I can just flip it on and off. I have 2 8" subs in a heavy box in my cabrio and its a bitch to take out. Anyone have any suggestions? or what the prob might be?
eykeykeyk is offline   Reply With Quote
Old 07-03-2009, 04:54 PM   #2 (permalink)
Date registered: May 2005
Vehicle: 99CLK320
remote start
Do you really have a remote start that was an aftermarket install or are you talking about your smart key? If it is the former I would say that would be the source of your problem and you might want to trouble shoot it through the maker. If it is the regular MB key I don't have a clue. You want to try to use the Search function on this website to see if anyone else in the other forums have encountered the same issue.
dlbehrns is offline   Reply With Quote
Old 07-03-2009, 06:52 PM   #3 (permalink)
This would be the factory MB stuff. Ive already changed out the Door Control Module.
Need Help w/ door locking and unlocking by it self and could not lock the car ashim W163 M-Class 7 12-29-2007 07:40 AM
Programming Keys for 1-door or 4-door unlocking BKHammond W204 C-Class 7 11-23-2007 06:13 PM
Door not opening after unlocking keywestwego W140 S-Class 3 01-16-2007 01:05 PM
Unlocking the door manualy SirOracle W168 A-Class 0 09-11-2006 03:22 AM
door unlocking - almost embarrassed to ask alexnatt W124 E,CE,D,TD Class 0 11-11-2005 01:57 PM
