Unexpected Oil Leak - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 11-30-2008, 03:37 PM Thread Starter
Date registered: Dec 2007
Vehicle: CLK 430 Cabriolet
Unexpected Oil Leak
My car has been sitting up for 3 months and I just started it and noticed a leak on my passenger side manifold. Why would your car start to leak after left to sit for that long? Is it the valve cover gasket, other gasket, plugs, etc?
Thanks in Advance.
bigpimp is offline
post #2 of 6 (permalink) Old 11-30-2008, 06:21 PM
Date registered: Aug 2008
Vehicle: 1999 CLK 320
bad things happen when a car sits to long
enyce284 is offline
post #3 of 6 (permalink) Old 12-01-2008, 01:43 PM
Date registered: Jul 2008
my mercedes tech said that these cars are not built to take on short trips and should not be left to sit there without driving it. he said that all the fluids and lubricants begin to settle to the bottom of the engine and the seals begin to go bad. i had a major oil leak and had no idea wea it was coming from. turns out it was the oil galley reservoir
pharmclk is offline
post #4 of 6 (permalink) Old 12-01-2008, 01:59 PM
snakoiler's Avatar
Date registered: Feb 2005
Vehicle: 2002 430clk;2005 Yamaha YZF R1;08 Range Rover Sport
I have the same leak and I dont let my car sit that long, its a problem with our cars I believe....
Mod list:Carlssons front bumper, custom angel eye fogs, headlight rings, #1 pads, Eibach springs, Inmotion ECU tuning, chrome wheels, Illuminated door sills, in dash DVD and backup camera, complete audio system, AMG pedals, LED lights, Blk maple and chrome shift knob, blk maple center cover and door pulls, Zaino, H&R 10mm spacers, K&N filters, Magnaflow exhaust
snakoiler is offline
post #5 of 6 (permalink) Old 12-01-2008, 03:33 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 17 Post(s)
It's not just Benz.
The single worst thing you can do to a car is park it for extended periods. Seals and gaskets dry out, fuel gums and varnishes, etc.
The second worse thing you can do is drive predominantly short trips that don't allow the car to reach operating temperature and run at temp for a while. While that at least moves lubricants around (preventing the problems noted in the single worst thing above), it adds contaminants to the oil and never burns off moisture.
Take care and enjoy the ride,
Greg
Check Codes is offline
post #6 of 6 (permalink) Old 12-01-2008, 05:52 PM Thread Starter
Looks like mine is a leaking valve cover gasket. Bought the gasket for 21.98 planning to change it. Any tips or suggestions?
Thanks in advance!!!!
bigpimp is offline
  Mercedes-Benz Forum > Mercedes-Benz Coupe/Convertible Forums > W208 CLK Class
User Tag List
Follow up: OIL LEAK- Oil Pump GAsket Seal ???.Radiator Reservoir Issue Guess Hew W203 C-Class 0 04-10-2008 07:45 AM
Wiring loom - insulation falling off, water leak, oil leak sjc123456789 W124 E,CE,D,TD Class 3 02-10-2006 10:24 AM
oil leak... motor honey?...leak stop? b2d W123 E,CE,D,CD,TD,TE Class 1 04-11-2005 03:07 PM
My car is in the shop...Oil leak, windshield washer leak, and screw came off. chanm W163 M-Class 3 05-23-2003 06:21 AM
My 96 S320 to have a cracked engine block gasket, which cause a oil leak .All oil changes (more)... Guest (MBNZ) W140 S-Class 2 04-19-2002 01:34 PM
